Sohc turbo cooling issues
Old Jun 12, 2005 | 09:16 AM
civic_jdm's Avatar
Default Sohc turbo cooling issues
I used search and havent really found what i need...
i have a D16z6 in a 91 Hatch. Im running a stock ef radiator and having cooling issues. I am running a stock fan and also have a slim fan between radiator and intercooler on a switch. Now when i get on it hard its fiind but after a few good pulls on highway it starts to get hot like 3/4 or little more up the heat gauge and when i let off and coast for a bit or drive steady it goes back down. I also have had it start to get hot sitting there driiving lower rpms in town. Gets up to like 3/4 mark or more and starts to come down then goes back up.....Head gasket is good. I just am having issues. Could it be the turbo right next to the radiator. Think a dual core DA OR EG dohc vtec del sol radiator will work better? Will the d series hoses squeeze over the b series bigger holes in radiator??? Any help would be nice....Also have thought maybe air bubbles cuz normal driving or mild accelaration and some hard d riiving its fine......
Old Jun 12, 2005 | 09:27 AM
flashedDc5's Avatar
Default Re: Sohc turbo cooling issues (civic_jdm)
When I had my turbo single cam in my ef i had a 99 civic radiator and mine did fine... I was having cooling issues also when i would go into boost or just regular driving, i found out it was my head lifting off the block single cams have a problem with that with stock head studs..... are you getting coolant in your overflow jug??
Old Jun 12, 2005 | 09:43 AM
civic_jdm's Avatar
yep im getting some coolant into the over flow. I also heard i should retorque the head studs also after having it boosted
Old Jun 12, 2005 | 10:06 AM
turboman's Avatar
nevermind
Old Jun 12, 2005 | 10:49 AM
beerbongskickass's Avatar
Default Re: Sohc turbo cooling issues (turboman)
Get some ARP head studs and a new OEM headgasket. Back your timing down a little too. Hopefully this will solve your problem. It has worked for me so far.
Old Jun 12, 2005 | 10:51 AM
racinskittle's Avatar
Same thing happens to me. It's not the head lifting though. It doesn't do it when im boosting. It happens after. Sometimes it happens when im at idle as well. Turn off the car, turn it back on, it's fine.
Old Jun 12, 2005 | 10:58 AM
civic_jdm's Avatar
same here, also does it once in a while just cruising at normal speeds in town . just sometimes, never gets in red....just gets hot and comes back down. Could it be air bubbles maybe??? does it under boost but not all the time.....if i let it cruise for a few and get on it a few times its fine. but if i keep on it it gets hotter......also like i said in c hicago it gets up there anad comes back down again and then it stays fine at times....confused
Old Jun 12, 2005 | 11:01 AM
civic_jdm's Avatar
Default Re: Sohc turbo cooling issues (beerbongskickass)
beerbongkicksass.......i am running your tune in my car actually. Seems to run great so far besides the heating up probs. Like i said it hasnt got into red or over the hot mark just gets hot at different times ...under boost and at idle speeds
Old Jun 12, 2005 | 02:56 PM
civic_jdm's Avatar
bump
Old Jun 13, 2005 | 03:41 AM
civic_jdm's Avatar
up
Old Jun 13, 2005 | 04:52 AM
Default Re: (civic_jdm)
Try backing your timing down 2 degrees in the last 3 boost columns. I am only running 17 degrees total. Haven't had any issues since I changed my head gasket that last time.
littlewagon
Aug 21, 2011 10:52 PM
MugenT
Jun 1, 2005 04:23 PM
gt25CIVICex
Jul 16, 2004 08:20 AM
confucius
Apr 28, 2002 09:32 PM
d mafia
Jan 19, 2002 06:26 PM
