sohc turbo
Old Aug 9, 2003 | 06:09 PM
cxca64's Avatar
Default sohc turbo
i just finished my home made turbo kit it moves good and there is only one problem i have to fix
my setup is:
10 ohm resistors
V-afc controller
-40% hi,lo points
crossover points 98/99
boost sesative fule pressure regulator on a 1:1 ration
10 psi
fuel pressure is 37psi
does any body have any sugestions on what should be my next step to make more power should be i belive i have the fuel covered except a fuel pump which next
Old Aug 9, 2003 | 06:41 PM
teal EJ1's Avatar
Default Re: sohc turbo (cxca64)
Whats the rest of the setup?
Old Aug 9, 2003 | 07:27 PM
fsp31's Avatar
Default Re: sohc turbo (Peter North)
Is your problem the 37 psi fuel pressure? I'm not to clear on what you're asking. Are you running 450 cc injectors? A stock pump can only deliver about that much pressure under those conditions.
Old Aug 10, 2003 | 02:06 PM
scttydb411's Avatar
i would definately get it dyno'd with wideband tuning. you don't want to be the guy posting here next week saying your motor blew in a week.
sounds good so far. good luck with the set up.
Old Aug 10, 2003 | 02:08 PM
hybrid93SIvic's Avatar
Default Re: (scttydb411)
make sure you get it tuned.......anwyays...good job for a pieced together kit...i'll be pieceing mine together as well on my b16.....good job
DC2
Oct 21, 2004 10:34 AM
Toptul_Honda
12
Apr 6, 2004 01:19 PM
zseeanz
Jan 28, 2004 07:58 PM
Familycarfromhell
Feb 11, 2003 06:01 AM
HybridCoupe
Jul 6, 2002 03:48 PM
