Fuel pressure DROPS when in boost
Old Oct 20, 2004 | 03:49 PM
DC2's Avatar
DC2
Default Fuel pressure DROPS when in boost
Whenever I give at least 30% throttle and approach around 4-5k in my gs-r w/SC61 I notice my fuel press. drops from mid 40 to mid 30 psi. I'm running an AEM EMS, Walbro 255 lph, MSD 754cc's, and a Dynamic Autosports FPR (chop the stock top style). Could the vaccum line be snagging?
Old Oct 20, 2004 | 03:55 PM
Finland's Avatar
Default Re: Fuel pressure DROPS when in boost (DC2)
Sounds like the piggy back regulator is not allowing a proportional increase in fuel pressure when under boost. The stock (un modified) regulator will give you about 1Psig of fuel pressure for each lb of boost.
Get yourself a new un modified stock regulator, or some other brand, and set the fuel pressure to stock, and tune away.....
The other possibility is the the fuel pump is starting to wear out, but that would be dependent on how many hours you have on it, that's how they are rated.
Go with your instinct though and check the vac line going to the regulator.
Old Oct 20, 2004 | 05:59 PM
m R g S r's Avatar
I'd say it's a reg problem, because that fuel pump should be able to handle 754cc injectors no problem.
Old Oct 20, 2004 | 06:01 PM
xci_ed6's Avatar
Default Re: Fuel pressure DROPS when in boost (boost psycho)
apply pressure to the reg. w/ the engine off and pump running, if the pressure increase is normal, check your pump. It is not flowing enough. this could be mechanical or electrical, so check your voltage at the pump under load (raise fuel pressure as high as you can w/o closing it off completely).
Old Oct 20, 2004 | 06:04 PM
Johnyquest's Avatar
I'd say along the lines of everyone else you should definatley check out the regulator but a clogged fuel filter could also be to blame.
Matt
Old Oct 20, 2004 | 06:49 PM
Freemantle's Avatar
Default Re: Fuel pressure DROPS when in boost (Johnyquest)
Where is the fuel pressure reading coming from? The end of the rail? Technically your fuel pressure always drops in boost, but if the probe is far enough away from the injectors you won't see it.
Old Oct 20, 2004 | 08:43 PM
B16A1-EF9's Avatar
Default Re: Fuel pressure DROPS when in boost (Freemantle)
I would say that it's the pump. Check your fuel filter also....and make sure the vaccums are all hooked up. Remember that the filter on the pump could be clogged also.
Old Oct 21, 2004 | 10:32 AM
DC2's Avatar
DC2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Freemantle &raquo;</TD></TR><TR><TD CLASS="quote">Where is the fuel pressure reading coming from? The end of the rail? Technically your fuel pressure always drops in boost, but if the probe is far enough away from the injectors you won't see it.</TD></TR></TABLE>
The sender is on top of the banjo on the fuel filter.
Old Oct 21, 2004 | 10:34 AM
DC2's Avatar
DC2
-The pump is fairly new, over a year old.
-I was suspecting the FPR is taking a ****. I don't mind swapping it out for a stock one.
Any more feedback?
eksleeper97
May 13, 2014 09:51 AM
teknics1
May 29, 2006 12:30 PM
Quick 200k Mile Motor
Jun 29, 2003 05:48 PM
HybridCoupe
Jul 6, 2002 03:48 PM
Brian_92GSR
Jan 20, 2002 01:27 PM
