SOHC - Which head gasket?
Old Feb 14, 2006 | 09:40 AM
spoon92hatch's Avatar
Default SOHC - Which head gasket?
A6 block - Y8 head
boosted 9:1 pistons
Which head gasket needed for this application?
TIA
Old Feb 14, 2006 | 10:33 AM
Hybrid96EK's Avatar
Default Re: SOHC - Which head gasket? (spoon92hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoon92hatch &raquo;</TD></TR><TR><TD CLASS="quote">A6 block - Y8 head
boosted 9:1 pistons
TIA</TD></TR></TABLE>
My understanding is Y8.
Old Feb 14, 2006 | 11:28 AM
Default Re: SOHC - Which head gasket? (Hybrid93Eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg &raquo;</TD></TR><TR><TD CLASS="quote">
My understanding is Y8.</TD></TR></TABLE>
thanks
Old Feb 14, 2006 | 11:32 AM
Rbehne2's Avatar
Y8
Old Feb 14, 2006 | 11:58 AM
EnzoSpeed's Avatar
I think you go by the head, right? If you have a vtec head, you need the vtec head gasket.
Old Feb 14, 2006 | 12:24 PM
Kelly.'s Avatar
I've quit using this account
Default Re: SOHC - Which head gasket? (EnzoSpeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnzoSpeed &raquo;</TD></TR><TR><TD CLASS="quote">I think you go by the head, right? </TD></TR></TABLE>
Old Feb 14, 2006 | 01:08 PM
Got_soy's Avatar
Default Re: SOHC - Which head gasket? (llewsirc)
I thoght it didnt matter, all d head gaskets are they same layout just different material.
the a6 is that graphite ****, z6 is metal and I think y8 is 3layer metal. If I remeber right
you can take a layer out of the y8 to boost compression but it's up to you.
Old Feb 14, 2006 | 01:10 PM
Hybrid96EK's Avatar
Default Re: SOHC - Which head gasket? (Got_soy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Got_soy &raquo;</TD></TR><TR><TD CLASS="quote">I thoght it didnt matter, all d head gaskets are they same layout just different material.
you can take a layer out of the y8 to boost compression but it's up to you.</TD></TR></TABLE>
I am pretty sure they are not all the same... I am also equally as sure they are ALL MLS.
Old Feb 14, 2006 | 02:04 PM
nonvtecD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg &raquo;</TD></TR><TR><TD CLASS="quote">I am pretty sure they are not all the same... I am also equally as sure they are ALL MLS.</TD></TR></TABLE>
you're wrong, pretty sure about them all being the same, and they are definitely not all MLS. I have used the composite/graphite HG's on a lot of my motors.
Old Feb 14, 2006 | 02:17 PM
Hybrid96EK's Avatar
Default Re: SOHC - Which head gasket? (nonvtecD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvtecD &raquo;</TD></TR><TR><TD CLASS="quote">
you're wrong, pretty sure about them all being the same, and they are definitely not all MLS. I have used the composite/graphite HG's on a lot of my motors.</TD></TR></TABLE>
And you used all OEM supplied gaskets? Or aftermarket crap?
Edit: Also somewhat interesting that Honda would have different part numbers for the supposedly "same" gasket...
Edit again: Even more strange that even FEL PRO shows a different part number.. so now what?
Old Feb 14, 2006 | 02:25 PM
douspray's Avatar
the y8 is MLS. i used the y8 on my boosted a6/z6.
Old Feb 14, 2006 | 03:13 PM
Hybrid96EK's Avatar
Default Re: SOHC - Which head gasket? (douspray)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by douspray &raquo;</TD></TR><TR><TD CLASS="quote">
the y8 is MLS. i used the y8 on my boosted a6/z6.</TD></TR></TABLE>
And the Z6 one I used on my engine was MLS... and the A6 I worked on had a MLS head gasket also, and the VX engine sitting in my garage is also MLS... do we see a pattern here?
Old Feb 14, 2006 | 03:30 PM
tilt's Avatar
I've pulled stock head gaskets on a d16a6 88 crx si and d15b2 91 crx dx. They both had the non-metal type that tears.
Old Feb 14, 2006 | 04:08 PM
liam821's Avatar
25 Year Member
Actually, you're wrong. The d-series dohc ZC has a different headgasket then the sohc blocks, and they arnt interchangable.
liam
Old Feb 14, 2006 | 04:34 PM
redzcstandardhatch's Avatar
something different
yeah, the dohc zc is different, but all sohc head gaskets are interchangeable.
they stock HG , honda one, for a d16a6 (well, any sohc, 88-91) was a graphite/composite, with fire rings.
they suck to take off the block.
Old Feb 14, 2006 | 04:42 PM
exsinnovation's Avatar
back on topic.... Use a Y8 gasket
Old Feb 14, 2006 | 07:03 PM
Got_soy's Avatar
Default Re: (exsinnovation)
so i was right, just like i thought
Old Feb 14, 2006 | 07:08 PM
Hybrid96EK's Avatar
Default Re: (Got_soy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Got_soy &raquo;</TD></TR><TR><TD CLASS="quote">so i was right, just like i thought</TD></TR></TABLE>
Correction there skip...
You might have been right about the composition of head gasket material.
You were NOT right in saying they are all the same between all D series.
Old Feb 14, 2006 | 07:19 PM
EnzoSpeed's Avatar
Actually, choosing the right gasket depends on what you want your compression to be. The a6 gasket is thicker than the y8 gasket and it will drop your compression by roughly a third of a point. But I would still stick with the y8 gasket since it's a quality 3 layer MLS.
And for those of you wondering, the z6 and y8 gaskets are the same, but they have different part numbers because they have different prices. In other words, Honda charges you more for the y8 gasket for no reason.
Old Feb 14, 2006 | 07:25 PM
Got_soy's Avatar
Default Re: (EnzoSpeed)
i wasnt saying the were the exact same i meant interchangeable but i couldnt think of the word so "the same came out"
Old Feb 14, 2006 | 07:34 PM
Everyones Hero's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnzoSpeed &raquo;</TD></TR><TR><TD CLASS="quote">Actually, choosing the right gasket depends on what you want your compression to be. The a6 gasket is thicker than the y8 gasket and it will drop your compression by roughly a third of a point. But I would still stick with the y8 gasket since it's a quality 3 layer MLS.
And for those of you wondering, the z6 and y8 gaskets are the same, but they have different part numbers because they have different prices. In other words, Honda charges you more for the y8 gasket for no reason.</TD></TR></TABLE>
I want to disagree with you on that last point. My Z6 gasket was around 60 from majestichonda whereas the Y8 gasket was around 23.
Old Feb 14, 2006 | 10:38 PM
EnzoSpeed's Avatar
Default Re: (Everyones Hero)
Yeah I don't know, it depends. I know in Canada the y8 is twice as much as the z6.
I just know they're the same gasket with different prices.
Old Feb 15, 2006 | 03:04 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exsinnovation &raquo;</TD></TR><TR><TD CLASS="quote">back on topic.... Use a Y8 gasket </TD></TR></TABLE>
thanks
Red_ED8
Feb 23, 2008 09:13 AM
mike93eh
Jul 19, 2005 08:04 PM
lessDXHB
Jul 13, 2005 10:53 AM
menappi
Mar 27, 2005 12:47 PM
94dxt
Dec 9, 2003 06:12 PM
