D series head gasket??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94dxt »</TD></TR><TR><TD CLASS="quote">but will both work fittment wise???</TD></TR></TABLE>
Yes, they will both fit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg »</TD></TR><TR><TD CLASS="quote">i thought that z6 and y8 headgaskets are the same thickness</TD></TR></TABLE>
They are. Both are 0.037". The funniest part is the Y8 head gasket is cheaper than the Z6 at the dealership.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 »</TD></TR><TR><TD CLASS="quote">They are. Both are 0.037". The funniest part is the Y8 head gasket is cheaper than the Z6 at the dealership.</TD></TR></TABLE>
That's why I was wondering the Z6 online is $45, the Y8 $26
How safe is it to buy a real thin headgasket to raise compression?
Will any other mods need to be done while doing this?
What dould it take? Links to where i can buy an high compression headgasket.
Motor:d16z6 w-i/h/e...98,000 miles with 200 compression all the way across.
Thanks
Sorry if i stole your thread-
Thanks
You need to make sure that you use the distributor for the head, you will need to change the plug over from the old one. The 2 different heads have the cam cut for the distributor differently. Its 1 tooth and about 20 degrees of timing. With out the right distributor itll run like ****.
JDMRPM
Sep 30, 2012 04:33 AM
sinfulj32
Nov 29, 2005 06:54 AM
philliecrx
Jul 9, 2005 12:14 PM
