kit im piecing together.... anything missing?
Old May 4, 2005 | 08:16 AM
stock00civic's Avatar
Default kit im piecing together.... anything missing?
The set up is going on a d16y8:
garrett 50 trim with .48 ar
spoolin performance manifold, i/c piping, 2.5" downpipe and dumptube
jrc 6" fmic
2.5" exhaust piping with universal muffler
hondata s200 w/boost
chipped p28 ecu
boost, egt, and oil pressure gauges
rc 550 injectors with clips
tial wg
blitz bov
wolboro fuel pump
wiring harness from jkbo
flamenco t oil feed and return lines
hallman manual boost controller
ebay catch can
i think thats it..... all i can think of right now anyways....is there anything that im missing? or does it sound alright? thanks.
Old May 4, 2005 | 08:21 AM
no2unenolife's Avatar
colder plugs? otherwise seems good
Old May 4, 2005 | 08:32 AM
Default Re: (no2unenolife)
oh yea.... forgot to mention the 2.5" resonator and the NGK BKR7E plugs.
Old May 4, 2005 | 08:52 AM
soon2brb240's Avatar
Does the catch can just go from the valve cover to can then can to pcv valve?
Old May 4, 2005 | 09:07 AM
BME1986's Avatar
Default Re: (soon2brb240)
Sounds good. I think i am gonna upgrade to a spoolin manifold once i get some more cash.
Old May 4, 2005 | 01:55 PM
Default Re: (BME1986)
Thanks for the feedback. Anyone else have any comments?
Old May 4, 2005 | 07:47 PM
Default Re: (stock00civic)
oh yea.... also forgot to mention stage 3 competition clutch and lightened flywheel.
Old May 4, 2005 | 08:58 PM
dthrone's Avatar
I would go with.....Head gasket...block guard..Head studs! Its a good idea!
Old May 4, 2005 | 09:07 PM
project dc2's Avatar
Default Re: kit im piecing together.... anything missing? (stock00civic)
gotta say i love that manifold package combo . i highly recommend spoolin performance
Old May 4, 2005 | 09:17 PM
Default Re: kit im piecing together.... anything missing? (project dc2)
Spanky..... I am going to go with those things you mentioned..... but its going to push me back a while longer before I would be able to get the kit on. Would I be alright running the set up mentioned at roughly 10 psi for a while? Eventually i want to put pistons, rods, and all that other good stuff, but for now I would like to get the kit on and see what kinda of numbers I can put down. I see people on here running around that same psi on stock internals and really havent had any problems (with a proper tune of course..... stoney at Velocity Performance should help me out there). And thanks again Phil for all of the help. I know that i hounded you with plenty of questions. What can I say..... I like to be reassured. I will be sure to post my numbers once everything is installed. Thanks again for the replies and feel free to add more.
Old May 5, 2005 | 08:17 AM
dthrone's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stock00civic &raquo;</TD></TR><TR><TD CLASS="quote">Spanky..... I am going to go with those things you mentioned..... but its going to push me back a while longer before I would be able to get the kit on. Would I be alright running the set up mentioned at roughly 10 psi for a while? Eventually i want to put pistons, rods, and all that other good stuff, but for now I would like to get the kit on and see what kinda of numbers I can put down. I see people on here running around that same psi on stock internals and really havent had any problems (with a proper tune of course..... stoney at Velocity Performance should help me out there). And thanks again Phil for all of the help. I know that i hounded you with plenty of questions. What can I say..... I like to be reassured. I will be sure to post my numbers once everything is installed. Thanks again for the replies and feel free to add more.</TD></TR></TABLE>
I would try to wait for the head studs head gasket and block guard if poss. its always better to be safe than sorry! If anything run like 7 psi untill you get these things! But i didnt even boost my Si-R G motor untill i had all of these things!
ketchup!
Mar 25, 2007 06:49 PM
ichbinsobose
Mar 28, 2006 05:05 PM
stock00civic
Jun 4, 2005 08:13 AM
StockCivicRacer
Jul 29, 2004 05:09 PM
