SOHC build up!?!
Old Feb 8, 2002 | 08:15 AM
GSRacer's Avatar
New User
Default SOHC build up!?!
i'm in the process of building up my 92 SI motor for boost. i just got off the phone w/ JE and they said that they only offer SRP pistons for a sohc vtec motors. i heard that SRP pistons are not that great when you go over 12 psi of boost. is there any other companies that produce really good pistons for this motor for boost?
Old Feb 8, 2002 | 08:20 AM
VTC_CiViC's Avatar
Default Re: SOHC build up!?! (GSRacer)
Find that hard to belive seeing as how Ben offer's JE's for SOHC's... as does SFP.
Old Feb 8, 2002 | 08:23 AM
GSRacer's Avatar
New User
Default Re: SOHC build up!?! (VTC_CiViC)
i just got off the phone w/ JE a couple of minutes ago. they said that they don't make JE pistons, only SRP's. any reputable companies that make good pistons?
[Modified by GSRacer, 12:25 PM 2/8/2002]
Old Feb 8, 2002 | 01:53 PM
ck279's Avatar
GSRracer, you got that 15.6 on a completly stock car??? If so, very impressive!
Old Feb 8, 2002 | 03:42 PM
gtcali's Avatar
I have JE pistons going in my sohc vtec. They do make 'em.
Old Feb 10, 2002 | 08:27 PM
GSRacer's Avatar
New User
Default Re: SOHC build up!?! (gtcali)
well it has a aem cold air intake. and a apexi muffler. the rest is untouched, i'll probably have the video soon. for some reason this car moves more than every other SI hatch that i raced. i guess it's one of the special ones.
Old Feb 11, 2002 | 04:51 AM
4dGSR at work's Avatar
use toyota pistons... i foget who but they are running 18 psi on them???
the 4dr silver civic... w/ the link stuff(thats why he stuck in my head)
he had a pic posted w/ a hood gap at the windshield if you recall
Old Feb 11, 2002 | 09:00 AM
downpipe's Avatar
Default Re: SOHC build up!?! (4dGSR at work)
that's "nathan's boosted civic" from thailand. search some archived posts for more info...
Old Feb 11, 2002 | 09:20 AM
TurboSedan's Avatar
New User
Default Re: SOHC build up!?! (downpipe)
Yep, he uses old Supra pistons. Cheap as hell too.
Old Feb 11, 2002 | 10:07 AM
psicrxsi's Avatar
Default Re: SOHC build up!?! (97CivicFerio)
wth...how does using supra pistons work? oh well when i do my build up ill be using eagle rods, srp pistons, race eng head gasket and block guard.......and the fuel...i dunno what to do about that yet.
Old Feb 11, 2002 | 06:12 PM
GSRacer's Avatar
New User
Default Re: SOHC build up!?! (psicrxsi)
ok, JE does make pistons for the sohc, but they have to be special order. they are not "off the shelf pistons" like the GSR. what about Arias, or Wiseco? are these good companies?
Old Feb 11, 2002 | 06:16 PM
VTC_CiViC's Avatar
Yes Arias and Weisco's are some good pistons too, kinda pricey though. JE's do more than enough for the $$, but I guess if you've got the $$ to spend, some Ross or Aria's sure can't hurt.
Old Feb 11, 2002 | 06:23 PM
GSRacer's Avatar
New User
what's the compression on these motors and what size are the pistons? does anyone know?
[Modified by GSRacer, 10:25 PM 2/11/2002]
Old Feb 11, 2002 | 06:26 PM
VTC_CiViC's Avatar
what's the compression on these motors and what size are the pistons? does anyone know? what about the engine code?
On what motors?? The SOHC's? We're talking about D16Z6's and D16Y8's here, SOHC VTEC 1.6L's. I belive they're 77mm pistons.
Old Feb 11, 2002 | 06:34 PM
GSRacer's Avatar
New User
thanks
Old Feb 11, 2002 | 06:36 PM
TurboSedan's Avatar
New User
STR8 outta Helms, 74.980-74.990 mm for D16 pistons.
Page 7-12.
Old Feb 11, 2002 | 08:04 PM
VTC_CiViC's Avatar
So 75mm piston's, thanks
Oh BTW, the stock CR is 9.2:1 for the D16Z6, 9.6:1 for the D16Y8
Old Feb 12, 2002 | 02:24 AM
downpipe's Avatar
they fit, they are cheap, (i think he pays about $25.00 each) and i believe they were designed for turbo use. (one of those old supras...i don't know too much about them)
Old Feb 12, 2002 | 03:17 AM
TurboSedan's Avatar
New User
NP
About the Supra pistons, I do not recall much from what Nathan said, hopefully he'll see this and help us out.
Old Feb 12, 2002 | 05:09 AM
GSRacer's Avatar
New User
yeah the supra pistons work, but he has to change every once in a while. he said that his only drawback is the pistons on his car. correct me if i'm wrong.
Old Feb 12, 2002 | 05:56 AM
VTC_CiViC's Avatar
Actually, I *think* he uses MR2 pistons, but I could be wrong. Seems to me like the bore size of the 2.0L MR2 would be alot closer to the 1.6L D-motor. Anybody seen Nathan around??
Old Feb 12, 2002 | 09:45 AM
GSRacer's Avatar
New User
i made up my mind. i just got off the phone w/ arias. i'm going to use the arias pistons. i'm going w/ 8.9-1 compression w/ .5mm oversized pistons.
Old Feb 13, 2002 | 05:32 PM
downpipe's Avatar
Toyota 1G-GTE (1st gen. Supra) pistons (75mm.. same size as the D16Y8's, believe it or not!)
JDM B16A connecting rods (modified to fit)
this is what he uses. pistons cost him aboout $20.00 each. check some of his archived posts for more info. it's all there.
[Modified by downpipe, 6:33 PM 2/13/2002]
Old Feb 13, 2002 | 08:07 PM
VTC_CiViC's Avatar
Anybody know the resulting CR?? The 1G Supra's weren't turbo'd right? That being true, those aren't exactly turbo ready pistons like 2JZ-GTE's would be
Old Feb 14, 2002 | 02:25 AM
downpipe's Avatar
i think his compression was 8.2:1, but i don't remember if he was running a thicker headgasket or not. i know some of the earlier supra's were turboed, but i don't remember the gen......i do knwo that they are very hard to find, though. a friend of mine just bought an old supra...
Xirish3x
Apr 25, 2008 11:00 PM
CovertFI
May 23, 2002 11:34 AM
ImportHatch
Apr 23, 2002 11:38 AM
paulzy
Jul 11, 2001 09:02 AM
