sneaky pete?
with a small shot like this you wont need to do anything. but if you want a bigger shot you want to upgrade you fuel delivery system. or retard your timing but that would hurt your power output when not juicin.
my friend has the incognito in his 00 si. looks nice in the glove box, but it dosnt do ****. when he sprays at the track it only took .1 off his times. he has ran it more than 10 times with no greater improvement, he ran back to back, all motor than spraying. he ran the same times. he even got it installed by a shop correctly. waste of money if you ask me. save up and get a real kit.
with a turbo it will give more because it will cool the intake charge and you should see more gains then .1
if i didn't get into a car accident i would have ran it and gotten some proof
Good point - with a turbo nitrous can give gains well above their standard hp rating. Then again, without turbo, .1 is all you should expect from a sneaky pete or similar - that's what they are designed for. The guys that use them are just looking for that extra little bit and don't want people to see that they have nitrous, whereas most of use are still working on taking larger chunks out of our times.
