Snapping a Rod using nitrous?!
Old Dec 11, 2003 | 09:46 AM
integranator's Avatar
Default Snapping a Rod using nitrous?!
I've been told that my friend should watch out for snapping a rod using a 75-100 shot on his D-series motor. Have you heard of anyone snapping a rod using nitrous?? We are going to build the head to take the shot, we were just wondering if we should upgrade the rods and pistons or not.
Old Dec 11, 2003 | 09:55 AM
dfoxengr's Avatar
Default Re: Snapping a Rod using nitrous?! (integranator)
never heard of a rod snap??
Old Dec 11, 2003 | 10:17 AM
Default Re: Snapping a Rod using nitrous?! (hybridvteceg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">never heard of a rod snap?? </TD></TR></TABLE>
I've heard of rods snapping yes, but I haven't heard much of rods snapping due to 75- 100shots.
Old Dec 11, 2003 | 10:19 AM
dfoxengr's Avatar
i was saying that ive never heard of a rod snap because of low nitrous shots
Old Dec 11, 2003 | 10:21 AM
TurbodCX's Avatar
Well just to let you know bro, i ran a NX 75 Shot on my D-Series for a little over a year with no problems at all. All i had was a FPR and a Fuel pump.
The car went 13.9@100mph on the SOHC!!
HTH
Brian
Old Dec 11, 2003 | 10:29 AM
Default Re: Snapping a Rod using nitrous?! (TurbodCX)
thnx man-- anyone else out there??
Old Dec 11, 2003 | 10:34 AM
Boostfed's Avatar
New User
The SOHC D series rods are known to be WEAK stock, general rule of thumb is no more than a 60 shot of nitrous and 7psi(of course depending on size of the turbo). Many have threw a rod on low shots like that but many have been succesful too. If you compared the SOHC rod to a B series you would understand why. They are extra thin on SOHC, some people will upgrade to a DOHC ZC rod I believe since they are a little stouter. Aftermarket forged is the only way to do it imo though
Old Dec 11, 2003 | 10:46 AM
Default Re: Snapping a Rod using nitrous?! (Boostfed)
^^ What about building the head up?? w/ some new valves springs...etc.
Old Dec 11, 2003 | 10:54 AM
gzrmoto's Avatar
i had a stock d-series rod snap on a 75 shot, it started to die going up the hill so i squeezed to make it up and then pop just enough speed to coast home
Old Dec 11, 2003 | 11:03 AM
T-sohctec's Avatar
Default Re: Snapping a Rod using nitrous?! (gzrmoto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gzrmoto &raquo;</TD></TR><TR><TD CLASS="quote">i had a stock d-series rod snap on a 75 shot, it started to die going up the hill so i squeezed to make it up and then pop just enough speed to coast home </TD></TR></TABLE>
yeah man, that will happen if you try & squeeze while going up a hill and in an innappropriate gear your are definately going to break stock D components. Think about the stress you put on the engine, Up hill in say 3rd or even worse 4th with your engine already starting to bog and then you hit the button.
No I don't think that upgraded valve springs are neccesary.
Stock D valves are realatively light and will hold on tight up to 8K RPMs. By the time you hit those revs your stock CAM has topped making power anyway so thre is no need for new springs unless you are putting in a cam that can take advantage of high RPMS.
Old Dec 11, 2003 | 11:34 AM
Default Re: Snapping a Rod using nitrous?! (T-sohctec)
i'm sorry, i meant to say-- what about upgraded valves, just so i don't have to worry about the valves burning up.
Old Dec 11, 2003 | 12:45 PM
RunonV8's Avatar
So we're basically looking at pistons, rods, and proper air/fuel tunning to a 12:1 and I should be fine?
Old Dec 11, 2003 | 03:41 PM
earl's Avatar
Default Re: Snapping a Rod using nitrous?! (RunonV8)
I had a rod bearing break into 4 pieces in a D motor using a 50 shot. Never saw that happen before. Replaced the one bearing and the motor was quiet again. Luckily it didn't spin...just broke in half.
Old Dec 11, 2003 | 05:34 PM
RunonV8's Avatar
Default Re: Snapping a Rod using nitrous?! (earl)
Damn...
Old Dec 11, 2003 | 05:48 PM
scatuli's Avatar
i would think there are many other things that would typically break before the rods themselves
K7-1Ktrevor
Nov 6, 2009 10:37 AM
shadow102
13
Jan 12, 2008 06:12 PM
TheDelSlo
Feb 2, 2006 09:20 AM
tnbigdawg
Nov 23, 2002 08:42 PM
