LS Engines RULE ! . . Dyno
Old Dec 10, 2003 | 12:32 PM
Darin D.'s Avatar
Default LS Engines RULE ! . . Dyno
**UPDATE** The car went 11.6@ 120 mph (2/29/04).
Finally got around to dynoing the car.
Pump gas 93 octane
Stock B18b with blockguard
Hondata S100
RC 550cc Injectors
Garret t3/t04e 54 trim 50 ar
Drag 3 manifold
tial 40 mm wastegate
full Skunk2 catback 2.25"
I tuned the car on the street and just wanted to do a couple dyno pulls to see what it was making. I used the Innovate LM-1 wideband for tuning...which is really nice btw.
This setup is in a 92 civic vx..and needless to say I have major traction issues.
Wideband was not hooked up on the dyno!
Modified by Willis at 9:59 PM 12/10/2003
Modified by Willis at 3:37 AM 3/8/2004
Old Dec 10, 2003 | 12:33 PM
Mr. Softee's Avatar
Default Re: LS Engines RULE ! . . Dyno (Willis)
um nice a/f ratio nice power though
what psi is that like *EDIT MISREAD* 13-16?
Old Dec 10, 2003 | 12:34 PM
Darin D.'s Avatar
Default Re: LS Engines RULE ! . . Dyno (94goldjungsr)
thanks!
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr &raquo;</TD></TR><TR><TD CLASS="quote">um nice a/f ratio nice power though
what psi is that like 9-10?</TD></TR></TABLE>
What I was thinking. You sure about that wideband
metal-x's Avatar
nice numbers but how long would that motor last
Old Dec 10, 2003 | 12:35 PM
AVATAR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr &raquo;</TD></TR><TR><TD CLASS="quote">um nice a/f ratio nice power though </TD></TR></TABLE>
I think I pee'd my pants
Old Dec 10, 2003 | 12:36 PM
flip1199's Avatar
how many lbs?
Old Dec 10, 2003 | 12:37 PM
Mase's Avatar
Default Re: LS Engines RULE ! . . Dyno (AVATAR)
im willing to bet the wideband on the dyno was not reading.
and im sure it was more than 9-10 psi.
Old Dec 10, 2003 | 12:38 PM
Mr. Softee's Avatar
Default Re: LS Engines RULE ! . . Dyno (Mase)
trq is rather low for 9-10, no?
for that power i would estimate 13-15.. but surely a good 250 ft/lbs
Old Dec 10, 2003 | 12:40 PM
Mr. Softee's Avatar
sheit i mis read 271 as 217 lol
Old Dec 10, 2003 | 12:43 PM
falcongsr's Avatar
What is this crap?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase &raquo;</TD></TR><TR><TD CLASS="quote">im willing to bet the wideband on the dyno was not reading.
you're probly right. i hope you're right for the motor's sake.
Darin D.'s Avatar
haha yea wideband on the dyno wasn't connected... i was running 23 psi. I also forgot to mention that im running a full skunk2 2.25" catback exhaust.
Old Dec 10, 2003 | 12:45 PM
Mr. Softee's Avatar
23psi on a stock motor LOL good lord
Old Dec 10, 2003 | 12:46 PM
igotyofire's Avatar
23lbs on a stock block?
Old Dec 10, 2003 | 12:47 PM
accordfreak's Avatar
stock internals except for the block guard right?
Old Dec 10, 2003 | 12:48 PM
1.8t's Avatar
That a/f can't be right....a stock motor wouldn't make it half way through a run like that without detonating like crazy and causing waves in the graph. Hell, I would even trust the motor to hold together
Old Dec 10, 2003 | 12:51 PM
RedlinedVTEC's Avatar
Default Re: LS Engines RULE ! . . Dyno (1.8t)
He said the wideband wasn't hooked up on the dyno.
TurboTegB18c's Avatar
Default Re: LS Engines RULE ! . . Dyno (igotyofire)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igotyofire &raquo;</TD></TR><TR><TD CLASS="quote">23lbs on a stock block?</TD></TR></TABLE>
Wow, that's freaking crazy!!!! and on 93 pump gas.
Old Dec 10, 2003 | 12:53 PM
RedTegLS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willis &raquo;</TD></TR><TR><TD CLASS="quote">... i was running 23 psi. </TD></TR></TABLE>
Ummm how are you running that much boost and not blowing up? Who tuned your car? God? I am jealous! Must be I need a block gaurd.
Old Dec 10, 2003 | 12:58 PM
Darin D.'s Avatar
Default Re: LS Engines RULE ! . . Dyno (RedTegLS)
I tuned the car. It is not blowing up for that reason.
Yes completely stock internals..I put new stock honda rings in it about 6 months ago along with the blockguard.
Mase's Avatar
somethings wrong here, i made 270whp on about 10.5 to 11 psi(that was w/ a dinky t04b drag 3 kit at that on my b18b which also had a 2.25 inch greddy exhaust) and it took you twice as much boost to make only 38 more whp?
Old Dec 10, 2003 | 01:01 PM
Johnyquest's Avatar
I like ALOT!
Old Dec 10, 2003 | 01:08 PM
AVATAR's Avatar
Default Re: LS Engines RULE ! . . Dyno (Johnyquest)
300 is very feasable on most B series engines stock with a good tune. Boost pressure is irrellevent. Nice powerband
Old Dec 10, 2003 | 01:10 PM
30psi Teg's Avatar
well i made 250whp on 23psi lol..
Shouldnt with a t3/t4 you be somwhere around 450 to the ground with 23psi.
300whp might be right with a t3 but not a t3/t4
Old Dec 10, 2003 | 01:14 PM
Ri5e's Avatar
23 PSI?
