smoking vents......
yea so when i am in boost and only when i am in boost smoke starts coming out of my drivers side vent whether i have it opened or closed(its a crx). Not much, looks almost white, like cigarette smoke not too thick though..... It doesn't smell like antifreeze but just wondering about suggestions about what it could be??
nope just smells like a turbo..... thats the weird part. ughhhhh ac was ripped out when we swapped in the b16, my bad, its a b16 turbo in a rex
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Wow.
Usually white smoke coming out of the vents is a BAD sign.
I know this, because when I had white smoke coming through the vents, my oil feed line had come undone and was dumping hot oil all over my engine bay.
That night sucked
That night sucked
The smoke could be blowby smoke coming out of your dipstick tube. I had the same problem on my car when the dipstick was toast. The gases would push my dipstick out and spray oil on my manifold causing it to smoke.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iiilgsrlll »</TD></TR><TR><TD CLASS="quote">The smoke could be blowby smoke coming out of your dipstick tube. I had the same problem on my car when the dipstick was toast. The gases would push my dipstick out and spray oil on my manifold causing it to smoke.
is there any way to solve the dipstick probkam ??
maby a sligthly bigger one from a different vehicle !?
</TD></TR></TABLE>is there any way to solve the dipstick probkam ??
nope i have been checkin my oil because i thought i was leaking, but no drips anywhere on the garage floor, and when i go to check my oil, the dipstick is still in there, its not hanging out
I had the same thing happen once, turned out to be smoke pouring out of the valve cover breather due to a broken ring land. Run the car with the hood open and look for smoke, hell check the compression why you are at it.
i'm betting you have your brether on your valve cover either vented to the air or have a filter over it.
am i right?
if thats so its blowby and is normal. Well its not normal but you'll need a good catch can with oil drainback and a source of vaccum to fix it since the stock honda pcv system sucks
am i right?
yea that **** is wide open, not even a breather on it..... yea, but upon further inspection i actually decied to get under my car and look around. The back of my block is covered in oil, is this from blowby? and i realized its hittin my downpipe which is probably why its smoking at wot basically. But do u think all of that oil on the back of my block is from that lil open valve? the black box on the back of my block(whatever that is) is covered in oil too, so the leak starts up high..... any past experiences with anyone?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK »</TD></TR><TR><TD CLASS="quote">
maby a sligthly bigger one from a different vehicle !?</TD></TR></TABLE>
Try getting an STR or Venom dipstick. They're discontinued for B-Series motors but some places still have some in stock.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ICeDoUt »</TD></TR><TR><TD CLASS="quote">yea that **** is wide open, not even a breather on it..... yea, but upon further inspection i actually decied to get under my car and look around. The back of my block is covered in oil, is this from blowby? and i realized its hittin my downpipe which is probably why its smoking at wot basically. But do u think all of that oil on the back of my block is from that lil open valve? the black box on the back of my block(whatever that is) is covered in oil too, so the leak starts up high..... any past experiences with anyone?</TD></TR></TABLE>
Have someone rev the car while you watch the breather. If you start seeing smoke or an abnormally high amount of oil squirting out then that's your problem. You could try running a catch can to catch the oil but that's a band-aid fix.
i'm a big boy i think i can manage to rev the engine by the throttle body/throttle cable hehe
, anyways, so theres no fix, just let it be? my one friend has a catch can and its a piece, fills up with oil in no time, and it just sucks, he's got a Z10 catch can
Have someone rev the car while you watch the breather.</TD></TR></TABLE>
Or you could do it yourself by pulling the throttle cable or throttle arm while still in the engine bay.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy »</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>\
Haha...sorry brain isn't functioning well this morning.
</TD></TR></TABLE>\Haha...sorry brain isn't functioning well this morning.
if its oil dripping on the dp it'll smoke all the time and a lot
if its smoke @ wot it's blowby and nothing to be afraid of unless it becomes excessive or blows a lot of oil all over the place (even most healthy cars will blow oil)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ICeDoUt »</TD></TR><TR><TD CLASS="quote">i never once did a compression check on my car, so what would the readings be like if my ringlands were toast?</TD></TR></TABLE>
if you're having a puff of smoke here and there its most likely not your ringlands unless its a fair amount of smoke.
test it anyway; if they're low then somethings not right
