smoking at idle
Old Sep 14, 2002 | 11:49 AM
vtecsiqt's Avatar
Default smoking at idle
i have 94 ls w/ a drag gen 3 kit motor only has 60k on it. it smokes sometime...pretty bad when idling usually after a boost run...is it possible that it could have a bad seals or a minute leak that is dumping oil on either side of it. i noticed when i swapped out the old motor for this one there was some oil in the pipe going to the intercooler and some on the filter side of it....there is only about 4 weeks of use on this.....at 10psi...it doesn't blow huge clouds at full boost like it did on the other motor which lost 100psi compression in the #1/2 cylinders
hammerj2
Mar 18, 2010 06:24 AM
spooledhonda
Aug 29, 2006 12:20 AM
vtecsiqt
Sep 7, 2002 01:52 PM
b18b25psi
Jul 30, 2002 11:16 AM
