smoke when coming to a stop/stopped
Old May 25, 2006 | 08:38 PM
sean's Avatar
Default smoke when coming to a stop/stopped
ok heres the situation.
everytime i downshift and come to a full stop at a light i will see smoke from my exhaust. its not alot but its enough for me to see and for my friends to ask me whats up with it.
when i get on the car it does not smoke at all. only after driving and then stopping at a light some smoke comes out but it is not constant. also i know that its oil because i can smell it and see it.
i was wondering what could be the cause of this. the car feels great and pulls hard, still feels really solid and has been boosted for over a year now.
setup is:
stock LS motor
sc61
550 cc injectors
short tubular mani
3 inch dp/exhaust
pushing 16psi and tuned with neptune by jeff evans
i ran an 11.8 when it was doing this also and pulling 116-118mph trap speeds.
thanks for any input. i just hope the motor isnt starting to go.
Old May 25, 2006 | 08:43 PM
hondaeg8's Avatar
Default Re: smoke when coming to a stop/stopped (sean)
kinked oil return line, valve seals, bad turbo could be a possibility
Old May 25, 2006 | 08:46 PM
wpgcivic's Avatar
hah bump to this because i have the EXACT same problem, i think i MIGHT be my turbo seals but not 100%
Old May 25, 2006 | 09:24 PM
pearl's Avatar
Default Re: (wpgcivic)
im going to say its the return line too... bump for sean.
Old May 26, 2006 | 07:31 AM
wpgcivic's Avatar
ttt
Old May 26, 2006 | 01:18 PM
underpressure02's Avatar
I got the same problem with my all motor car. If I get on it hard then get off and come to a stop or slow down and tap the throtle again it smokes. I can see the blue smoke so I know it is oil. I think it is valve guides but not sure.
Old May 26, 2006 | 01:29 PM
I3ooS710's Avatar
Default Re: smoke when coming to a stop/stopped (underpressure02)
My guess would be seals. If you're using a -4 feed line, change to a -3 or use a restrictor. I hope it's not too late. I've seen people ruin seals after 20 min or driving w/ a -4 line.
Old May 26, 2006 | 02:01 PM
Runnerdown's Avatar
Default Re: smoke when coming to a stop/stopped (I3ooS710)
this is a common trait on honda motors, boost or n/a when the ring seal is not so great. high vacuum on decel and when coming to a stop there a bit of smoke and oil smell.
Old May 26, 2006 | 02:21 PM
coneheadsracing's Avatar
Default Re: smoke when coming to a stop/stopped (Runnerdown)
I too have the same issue. Last year on a d series y7/y8 with my return line low in the pan it smoked, like yours. 3an line, and a good sized, no kink return line.
This year, rebuilt engine, full y8 this time, new return line, high up above oil line, still same problem. I'm leaning on time for a turbo rebuild personaly Piece of cake though. I also upgraded my pcv system this year, to a proper catch can, so thats not it either....
Old May 26, 2006 | 03:37 PM
wpgcivic's Avatar
i find that mine is really bad when its hot outside
Old Jul 7, 2006 | 11:53 PM
PINKS's Avatar
I want a CRX tattoed on my butt
EXACT SAME PROLBME HERE!!!
Old Jul 8, 2006 | 12:20 AM
A.E Motoring's Avatar
Default Re: (PINKS)
same problem here, but i pretty sure i know its my turbo, my compression is solid, and i can see oil seeping through the exhaust side on the ouside of it around the clocking blots and ****, and i know im using a bigger feed line than the -3an, i need a restrictor, too much oil getting into the turbo
Old Jul 8, 2006 | 02:05 AM
PINKS's Avatar
Default Re: (SPNFEDEH)
Maybe I'll grab a small restrictor at home depot
Old Jul 8, 2006 | 05:30 AM
stockredej1's Avatar
Default Re: (PINKS)
Mine does it to so im assuming this is pretty common haha. Just got my turbo rebuilt so we shall see if that stops it.
Old Jul 8, 2006 | 05:33 AM
PINKS's Avatar
Default Re: (stockredej1)
how much smoke?
Old Jul 8, 2006 | 07:14 AM
seen4ever's Avatar
Default Re: (PINKS)
valve seals normally, its the transistion form deep vacuum, where it sucks oil ontop of valves and you open up the trottle and suck it in.
or catchcan setup shooting oil into the intake... but normally this is valveseals.
Old Jul 8, 2006 | 07:25 AM
Default Re: (PINKS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PINKS &raquo;</TD></TR><TR><TD CLASS="quote">how much smoke?</TD></TR></TABLE>
Mine is only a littl poof when i come to a stop *sometimes* it doesnt do it every time. When my car was on the dyno it would to it after every pull when the revs dropped back down. so when vacuum changed.
Old Jul 8, 2006 | 02:27 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stockredej1 &raquo;</TD></TR><TR><TD CLASS="quote">
Mine is only a littl poof when i come to a stop *sometimes* it doesnt do it every time. When my car was on the dyno it would to it after every pull when the revs dropped back down. so when vacuum changed.</TD></TR></TABLE>
yea mine is that like that too, same happend on the dyno
Mattb16teg
Nov 13, 2010 06:19 PM
superslow-oto
Jun 11, 2008 10:57 AM
cooltron
Mar 28, 2008 01:54 AM
Mr.DC2TurBo
Oct 7, 2004 07:05 PM
SlowB16
Jun 2, 2002 03:25 PM
