Smoke at Idle!
Old Mar 19, 2005 | 07:47 AM
QuickEJ6's Avatar
Default Smoke at Idle!
Blue/white Smoke only at idle.
HeadGasket or Turbo(return line?)
Old Mar 19, 2005 | 11:05 AM
u2civic1's Avatar
Default Re: Smoke at Idle! (QuickEJ6)
where is the smoke coming from?
Old Mar 19, 2005 | 09:32 PM
NVturbo's Avatar
O.G. triple O.G.
Mine is doing the same damn thing. I believe my problem is that I need to shorten my oil return line and run smaller oil feed line.
Old Mar 25, 2005 | 11:27 PM
Evo-man@20psi's Avatar
Default Re: Smoke at Idle! (u2civic1)
Good question it could be anything
Old Mar 25, 2005 | 11:43 PM
s2kdre's Avatar
Default Re: Smoke at Idle! (Blue00vtecsi)
smaller feed line isnt gonna make a difference, 4 an is most common, you're still gonna get the same oil pressure no matter what line you use.
Old Mar 26, 2005 | 08:13 AM
PrettyLude's Avatar
Default Re: Smoke at Idle! (jdmhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhonda &raquo;</TD></TR><TR><TD CLASS="quote">smaller feed line isnt gonna make a difference, 4 an is most common, you're still gonna get the same oil pressure no matter what line you use.</TD></TR></TABLE>
4 would be big, you would need a restrictor
Old Mar 26, 2005 | 09:33 AM
SOHCmaster's Avatar
Funny my car does it too, but not all the time, but yes mostly at idle.. Some days its normal, Ive been trying to solve this as well..
Old Mar 29, 2005 | 04:59 AM
quicksol95's Avatar
Default Re: (JDMDC2909)
if you are using a -4an line you need a oil restrictor
Old Mar 29, 2005 | 08:27 AM
H22A_NeThing's Avatar
Default Re: (slow90hatch)
yup, you definitely need a restrictor, which is a good idea on hondas anyway, there's a lot of excess oil pressure in hondas that tries to puch oil past the seals, I've heard of several cases of this, the restrictor always fixed it
Old Mar 29, 2005 | 08:45 AM
m R g S r's Avatar
it could be too much pressure going in....but I'm thinking it's the return line, which is not letting enough oil back into the pan fast enough, causing it to push past the seals and get sucked into the engine....
stackz
Feb 28, 2008 01:49 PM
hondaeg8
May 23, 2006 11:53 AM
Boltz
Nov 2, 2004 05:16 PM
hitvtecgetloud09
Aug 26, 2004 09:43 AM
rpm9100
Jun 13, 2003 03:55 PM
