smell of coolant when boosting. problem? yes? no?
Old Jun 23, 2003 | 10:32 AM
igo4bmx's Avatar
Default smell of coolant when boosting. problem? yes? no?
i smell burning coolant occasionally when boosting and i'm worried something is wrong.
i'm boosting about 5-7 on a stock d16 motor
any ideas?
Old Jun 23, 2003 | 10:38 AM
TurboDANDEE's Avatar
is your coolant level decreasing? if so, then i would look into it, but if its not overheating, then its not a major problem. god luck.
Old Jun 23, 2003 | 10:42 AM
igo4bmx's Avatar
Default Re: (TurboDANDEE)
definately not overheating. temp shows at horizontal, and no visible signs of leaking or anything...
Old Jun 24, 2003 | 08:02 AM
Drag_On's Avatar
check to make sure your turbo hot side piping isnt near or touching your coolant lines. I had that problem with the smell and a week or so later I had a hole in one coolant line.. Good luck
Old Jun 24, 2003 | 01:51 PM
igo4bmx's Avatar
Default Re: (Drag_On)
eek!!!
thanks for the info!
Old Jun 24, 2003 | 02:50 PM
MiraiZ's Avatar
Default Re: (igo4bmx)
I had the same problem a few months ago after I got my engin rebuilt...it turned out to be the smell of new thermal wrap burning in...do a search for "pancakes"
Old Jun 24, 2003 | 03:14 PM
madman604's Avatar
Default Re: (MiraiZ)
check the water pump area. when the pump dies it starts to "weep" there. if the pump goes...you entire valvetrain follows
Joshable14
Jul 20, 2015 10:10 AM
flipldls
May 9, 2010 02:14 PM
vinceiscoo
12
Sep 5, 2008 11:02 AM
Praylewd powr
Oct 13, 2005 10:51 AM
Allstar
Feb 26, 2003 05:55 PM
