...SMC... Wow...
Old Oct 12, 2002 | 08:18 PM
  #26
pelotudo's Avatar
Default Re: ...SMC... Wow... (mos)
I finally got her fixed. Some F*tard (whoever had the car before me and Jeff) basically stripped the blue tach wire (On the dizzy), then wrapped his aftermarket tach on it and stuck electrical tape on it. After wear and tear, it was hanging on by like 1 strand, and that's what was causing the problems. I soldered it back together, heat shrunk it, and everything is working perfectly again.
jB
Old Oct 12, 2002 | 08:24 PM
  #27
rjardy's Avatar
Default Re: ...SMC... Wow... (PelowisheshewascoolTudo)
Awesome, so the tach signal wire was causing all those problems?
Did you get the injector fixed?
Rob
Old Oct 12, 2002 | 08:31 PM
  #28
pelotudo's Avatar
Default Re: ...SMC... Wow... (rjardy)
Yeah. It had like 1 strand hanging on.
The injector is being weird. Like, when the car is cold it will leak a little bit until everything warms up. I drove it all day today and tonight, and it didn't leak a drop the entire time.
jB
Old Oct 12, 2002 | 08:42 PM
  #29
shadowdawn's Avatar
Yep, the hack via afc or smc are a really nice low boost setup :D :D
Old Oct 12, 2002 | 09:19 PM
  #30
mos's Avatar
mos
Default Re: ...SMC... Wow... (shadowdawn)
Glad to hear everything is working well now pelo!
Old Oct 13, 2002 | 07:13 PM
  #31
willyboyK20's Avatar
do you have that hesitation problem like the guys with the afc hack have?
Old Oct 14, 2002 | 04:26 AM
  #32
pelotudo's Avatar
Default Re: ...SMC... Wow... (willyboyD16)
Where should I be noticing it? I had a slight hesitation problem before I even put the turbo on, but it is fixed now after I got the tach signal wire fixed.
The only choppy point I have is going at partial throttle, while cruising at the same speed. Other than that, everything seems smooth so far.
jB
Old Oct 14, 2002 | 10:10 AM
  #33
Jason kiDD's Avatar
That would be it.. Part throttle woes..
Old Oct 14, 2002 | 12:18 PM
  #34
redline201's Avatar
Default Re: ...SMC... Wow... (Jason kiDD)
so with the smc you still get the booggy hesitation at partial throttle (just cruising speed???)
Old Oct 14, 2002 | 12:26 PM
  #35
pelotudo's Avatar
Default Re: ...SMC... Wow... (redline201)
Yeah.
jB
Old Oct 14, 2002 | 02:04 PM
  #36
rjardy's Avatar
any way around that?
Rob
Old Oct 14, 2002 | 03:24 PM
  #37
blufke's Avatar
Rob
yeah really. that sux.
Old Oct 14, 2002 | 04:39 PM
  #38
Default Re: ...SMC... Wow... (blufke)
that is what i am thinking. I believe this is why the VAFC hack is a little better than the smc because u are able to tune both wot and part throttle on it. If I am wrong somebody correct me. I've done "ALOT" of research but i am still no expert.
Old Oct 14, 2002 | 05:07 PM
  #39
pelotudo's Avatar
Rob
Really guys, it's not as bad as you guys make it to be. It's just a little "burp" every now and then. I drove my car about 40 mins today, and didn't feel it at all. It's just certain times that I have noticed it, and it's not bad when it happens. The second you go over like 1/3 throttle, it's gone and you're boosting away...
jB
Old Oct 16, 2002 | 08:36 AM
  #40
mos's Avatar
mos
Do you guys think the heavy stock flywheel would help with the part throttle "burp?"
Old Nov 13, 2002 | 09:37 AM
  #41
redline201's Avatar
that damn part thottle burp is whats keeping me away from these hacks
damnit
hondata is so damn expensive
Old Nov 19, 2002 | 05:16 PM
  #42
accordfreak's Avatar
what is a dizzy?????
Old Nov 19, 2002 | 05:42 PM
  #43
Blaze45's Avatar
Brrraaaap!
Default Re: ...SMC... Wow... (accordfreak)
Glad to see that the SMC is working out for you. Hope ya get the burps fixed.
a dizzy = distributer
Blaze
[Modified by Blaze45, 2:43 AM 11/20/2002]
spotscivic
Mar 6, 2008 10:07 AM
specv5150
Jun 6, 2004 06:37 PM
94TealGSR
May 18, 2003 11:26 PM
zip
Nov 27, 2002 08:39 AM
Hybrid
Sep 13, 2002 05:56 AM
