SMC + DSM 450 troubles
Old Oct 30, 2002 | 06:16 AM
MintFlavored's Avatar
Default SMC + DSM 450 troubles
What's up Honda-Tech, long-time reader, first time poster.
Ok, I have a 96 Civic with a b18b and a drag 3 kit. this weekend I installed a new fuel rail and adjustable fuel pressure regulator, 450cc DSM injectors with 10W 10 Ohm resistors, a walboro 255lph intank pump, and a SMC. I have gone back and checked all of my wiring, which I soldered, and everything seems to be ok.
Now here's the problem: the car will start, and if I rev it, it will do that ok, but it will not idle. If I don't step on the gas, the car will die immediately after I start it. It also smells like unburnt fuel is coming out of my exhaust. I know this must mean the smc isn't tuning the injectors right, but I did a test with a volt meter, and it looked like the map voltage was being trimmed ok. Something like 1.2v - .7v. I just don't understand what it could be. I pulled the rpm signal from the line going from my msd box to my tach. I've tried fiddling with the % trim on the smc, but no matter what I put it at, it does the same thing. Any help would be great
Old Oct 30, 2002 | 06:18 AM
TurBoXBirD16's Avatar
Default Re: SMC + DSM 450 troubles (MintFlavored)
maybe the FPR??
check it around...
Old Oct 30, 2002 | 06:26 AM
RGAZ's Avatar
New User
Your fuel pressure is too high.
Check your fuel pressurea nd the FPR to verify they are correct.
My bet is the new 255 pump is too much for the stock fpr. You may need a bypass hole or a seperate fpr.
I know that is the problem because I had it too.
Randy
Old Oct 30, 2002 | 06:27 AM
Ok, I pulled the adjustment screw all the way out of my fpr (which is a venom, by the way- I got it for cheap!) It seemed to idle a little longer... is there any way to reduce my fuel pressure any more??
Old Oct 30, 2002 | 08:02 AM
SlowB16's Avatar
maybe put your stock fpr back in??
Old Oct 30, 2002 | 08:29 AM
sagaprelude's Avatar
Default Re: SMC + DSM 450 troubles (SlowB16)
i thought u had to keep everything stock for the smc and 450s to work, just like the vafc hack, so i agree, put ur stock fpr back in
Old Oct 30, 2002 | 10:43 AM
Well, I borrowed a Fuel Pressure Gauge, and it says my fuel pressure is about 40psi at idle. It's still running so rich that it backfires at any sort of rpm, and dies if left at idle. Could the SMC be malfunctioning? I'm getting close to being out of ideas.
Is it possible to attach the stock fpr to an aftermarket rail?
Old Oct 30, 2002 | 10:52 AM
take out the walbro and venom, ur only supposed to run the smc with the 450s, ur stock fuel pump and stock fpr.
Old Oct 30, 2002 | 11:11 AM
DUCK COMMANDER's Avatar
Default Re: SMC + DSM 450 troubles (sagaprelude)
40psi with 450 injectors if too much fuel...big difference bwtewwn 450 at 40 psi and 240 at 40 psi
Old Oct 30, 2002 | 12:29 PM
Ok, I trimmed the fuel pressure, and hooked up the vacuum line to the input, and have tried everything from 15psi at idle back up to the 40 I had originally. None of those changes seems to have made any difference.
I pulled my plugs, and they are all very fouled. Is it possible that the SMC isn't working?? I've tried idle - 1.5k settings of everything from about 30% all the way to 55%. The rest of the settings are all aobut -40%.
As far as removing the walboro, it even says in the smc instructions that an aftermarket pump is neccessary for 8+ psi.
Old Oct 30, 2002 | 01:06 PM
blufke's Avatar
you can use an aftermarket fuel pump but put your stock fpr back on there. see if that does it.
Old Oct 31, 2002 | 06:31 AM
Just want to see if anyone has any other ideas. I'm kinda stumped here.
Old Oct 31, 2002 | 07:54 AM
badCRX's Avatar
New User
I would suggest to try your stock pump and fpr for the simple sake of process of elimination.
Old Oct 31, 2002 | 01:17 PM
Bump for more thoughts.
Old Oct 31, 2002 | 01:31 PM
GraphiteAccord's Avatar
did you even bother with what badcrx said?
Old Oct 31, 2002 | 04:02 PM
I sure didn't. I would like to see if anyone had a more specific idea about what it was. If noone does, I probably will change my rail and regulator back to the stock ones. If that doesn't work, I guess I'll go back to my original pump. If you look back to the things I have done already, I'm starting to think it's an electronic problem.
I'm sure there are plenty of people running a similar set-up, and I would like to get it running with all of the parts I have, instead of pulling them off. I know that it may be unavoidable, but like I said, I just wanted to see if anyone knew what it was before I started pulling things off...
Old Oct 31, 2002 | 04:56 PM
shadowdawn's Avatar
I have a AFC and 440 injectors AND a walbro 255hp pump so you your intank pump should NOT be the problem.
Also I was having misfire codes CEL thrown at me fro a while after changing to AFC hack and AEM fpr... so I went back to stock FPR to see if it rids my problem and for a week now still no misfire codes.... Just food for thought. My idle pressure with the 440's + intank + stock fpr is almost 48psi with vac line connected....
Old Nov 1, 2002 | 01:29 PM
Well, I just put my stock fpr on my shiny new rail, and it works alright now. Shadow Dawn, what are your afc settings? I just want to know what you set it at idle so that it would idle.
My fuel pressure is about 40-45 psi, should I think about drilliing my regulator to allow more fuel to pass? Thanks for all the help guys.
Old Nov 1, 2002 | 03:32 PM
OK, I still can't get it to hold an idle, I can drive it around, and loosing traction in 3rd is kinda nuts. Like I said, my fuel pressure is about 40 lbs, with the vacuum line attached. Should I drill out the fuel pressure regulator? Anyone who has any experience who could help me would be great.
[Modified by MintFlavored, 12:41 AM 11/2/2002]
Old Nov 1, 2002 | 07:26 PM
rjardy's Avatar
there is an artile on this by the old one, but i cant find it, anyone have it?
Rob
Old Nov 1, 2002 | 08:58 PM
shadowdawn's Avatar
My exact afc settings are posted on my website.... but honestly in my experience the 1000rpm setting on the afc does not affect my idle at ALL, from 20% to 40% it didn't make a god damn difference....
Sounds like your problems are non afc/fpr related... perhaps your dsm injectors are defunked? one or more of them? or mabye a wiring problem with a resistor pack or something?
rice a roni
Engine Management and Tuning
Apr 26, 2026 03:22 PM
ryan_1014
Feb 19, 2009 09:11 AM
93CX
25
Apr 11, 2007 11:31 AM
technine
Dec 16, 2002 02:09 PM
freeplay
Oct 20, 2002 09:05 AM
