CEL code 45
Old Sep 11, 2004 | 06:14 AM
boosted k20's Avatar
Default CEL code 45
whast up. well i was drive n my car yesturday and was accelerating to get onto the highway. when i did that i threw a CEL code 45, which is system too rich. in my car i have I/H/E, MSD ignition and a SAFC. i dont have any fuel upgrades like fuel pump, FPR, etc. The settings on my SAFC is set to lean the mixture out a little bit, only about -8%. i pulled over and set all my settings back to stock on the SAFC and reset the ECU.
i was just wondering why did i threw that code for system rich?
Old Sep 11, 2004 | 08:00 AM
tub_sephiroth's Avatar
Default Re: CEL code 45 (boosted k20)
Do you have bigger injectors? Cause code 45 could be lean or rich.
Old Sep 11, 2004 | 09:29 AM
gsrboi80's Avatar
its probably running too lean not to rich <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tub_sephiroth &raquo;</TD></TR><TR><TD CLASS="quote"> Cause code 45 could be lean or rich.</TD></TR></TABLE>
Old Sep 11, 2004 | 05:36 PM
YoungOne's Avatar
Old Sep 11, 2004 | 06:46 PM
Default Re: CEL code 45 (YoungOne)
i didnt know that the code could mean that im running lean too. thanks for the info. I'll just leave the safc settings the way they are until i get it dyno'd after i install my cams
Old Sep 11, 2004 | 07:23 PM
set the settings to 0 if you have stock injectors.
Old Sep 11, 2004 | 07:32 PM
Default Re: CEL code 45 (tub_sephiroth)
yea thats what i did. everything is set to zero. i read that u can tune the afc with the a/f ratio gauge. just keep lean n out the engine until the light drops to stoich. i guess i should have listened to that advice. i need to get it on a dyno in order to tune it
94typeR
Mar 31, 2007 03:57 PM
376R
Oct 11, 2005 04:40 AM
JM Performance
Dec 19, 2001 07:07 PM
newt2
Jul 6, 2001 07:58 AM
