slow spool up
Old Aug 17, 2004 | 09:59 AM
Mr_Bojangles's Avatar
Default slow spool up
I got my turbo all functioning, got charge pipes to stop shooting off and same with vacuum hoses
However, I am having two problems, still...
a) all my exhaust manifold bolts keep unwinding.
and
b) the turbo is spooling at around 4,500 rpms and doesn't reach 7 psi till right after redline (about 7000rpms) which seems very slow for a 14b. Is this because of the bolts not being tight or is their another common cause?
Old Aug 17, 2004 | 10:04 AM
SOHC_MShue's Avatar
Default Re: slow spool up (Mr_Bojangles)
check for leaks in your charge pipes and make sure your internal wastegate isn't leaking or something.
Old Aug 17, 2004 | 10:06 AM
underpressure02's Avatar
this may sound dumb but all of a sudden my was slow and it was taking forever to spool the turbo. I found that my fuel rail was leaking where the top of the injectors go into the rail. I fixed that and was good to go again.
Old Aug 17, 2004 | 10:09 AM
beepy's Avatar
Probably because of the bolts.
If they keep coming out, use safety wire.
Old Aug 17, 2004 | 10:53 AM
HatchSi's Avatar
use lock washers???
Old Aug 17, 2004 | 10:54 AM
tgreaves's Avatar
Default Re: slow spool up (beepy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy &raquo;</TD></TR><TR><TD CLASS="quote">Probably because of the bolts.
If they keep coming out, use safety wire.</TD></TR></TABLE>
WTF is safety wire????
Old Aug 17, 2004 | 10:57 AM
Boost Addict's Avatar
Default Re: slow spool up (tgreaves)
I bet anything you have a leak in your charge pipe.
Old Aug 17, 2004 | 11:19 AM
Default Re: slow spool up (xPRELUDEx)
I had to look safety wire up to. It is a really cool idea, just a little complecated for the amount of space I have to work.
http://www.geocities.com/robm3....html &lt;-- safety wire info
Do you think lock washers would do the trick?
Old Aug 17, 2004 | 11:25 AM
toolowsol's Avatar
i have lock washers, mind seem to be staying secure, but it has only been 3 days but they are still very tight
My advice is to get lock washers, and tighten everything again after the turbo is hot
Old Aug 17, 2004 | 11:28 AM
Default Re: slow spool up (toolowsol)
aren't bolts easier to snap when they are hot? I have bad luck at snapping bolts
not a r
May 28, 2008 04:06 PM
mrlegoman
Jan 15, 2008 09:20 AM
racin jasin R
Dec 4, 2006 04:27 AM
_Endless_
Jun 9, 2003 06:58 AM
TurbothisLS
Sep 6, 2002 09:06 PM
