Slow spool...Drag Kit ????
Old Jun 15, 2009 | 06:49 PM
jdmintegra18's Avatar
Default Slow spool...Drag Kit ????
Hey whats up fellas i have a jdm gsr block i built for boost eagle rods,wiseco 8:9:1 pistons and all that good stuff...i had the car street tuned on 14psi and it ran great would spin very badly throu 2nd into 3rd..now for some reson the turbo spools slower than it used to..like in 1st it would start building boost the smack the revlimiter now it pulls but dosent break the tires loose and have near the power it felt like it used too..and i have a open loop dump tube and it used to be pretty loud once opend up but its not loud at all....im thinkin it the manual boost controller..its a tial 38mm with 8psi spring and turbosmart mbc but its about 5-8 years old...would i mbc play this roll causeing the wastegate to act alil funny..im hoping yall say yes because ive checked for leaks and cant find anything...ive ordered a new mbc..thanks for your help
Old Jun 15, 2009 | 07:38 PM
TheShodan's Avatar
Moderator
Default Re: Slow spool...Drag Kit ????
No. (If I'm reading your message correctly) sounds like it may be in the turbocharger itself. Check for any wet oil leaks in the downpipe, blue smoke, or any strange sounds. Also check the intake of the turbo itself for any shaft play or damage in the turbo.
Old Jun 16, 2009 | 07:04 AM
912's Avatar
912
maybe your clutch thats what happen to me
Old Jun 16, 2009 | 10:31 AM
Wopsicle69's Avatar
what are you using for a turbo filter??
If your using a cone filter it may be dirty, try to give it a clean or buy a new one.
Just dont use screen mesh over the turbo, very cheap, very gay.
Old Jun 16, 2009 | 01:43 PM
ok let me reword this...the turbo spools fine but sometimes it goes to 9psi then maybe 12 then maybe 14 i have it set on 1bar..thats why i said i think its the mbc..and my dump pipe isnt as loud as it used to be maybe because it bleeding out alil...it used to build boost then hit the set point and come alive and the dump was loud as ****..i have a joe p mbc on the way so we will see
Old Jun 16, 2009 | 02:22 PM
cnydc2's Avatar
What psi spring is in the WG? You could always bypass the MBC and see if the WG its self is malfunctioning.
pbzhb
Feb 19, 2008 11:50 AM
VTEC-in_Beaver
Feb 2, 2008 11:11 AM
DCkazi
Jun 22, 2006 11:18 AM
nigel
Aug 7, 2003 12:08 PM
HotRodTeg
Oct 28, 2002 08:43 AM
