slow cranking
Old May 10, 2009 | 04:46 PM
Scheizty's Avatar
Default slow cranking
I got the motor back from the builder and everything is back in. I hand cranked it while the timing belt was put on, and it turns like normal, maybe a bit harder.
Now that the battery is back in and all, the first crank was really slow. It turns slow, fires, but not fast enough. Thinking that it was the battery, I had two different cars try to jump start it. Still a slow crank. I even tried a new battery, still the same. The starter was tested, and it turns normally, just not in this motor. I cleaned the grounds and even added new ones; no dice.
Giving up on the starting system, I even did a push start. The engine wants to go, but it doesn't move fast enough. I checked the hand crank again, still okay.
I thought this should go into forced induction since this is a low compression engine rebuild issue.
Old May 10, 2009 | 05:04 PM
vietjdmboi's Avatar
Default Re: slow cranking
have the checked the timing belt to see how tight it is?
Old May 10, 2009 | 05:19 PM
Scheizty's Avatar
Yeah, it's good and so is the alternator. Timing belt and alternator are the only belts on the motor.
Old May 10, 2009 | 05:25 PM
boostedcivicsir's Avatar
Mr. Badwrench
how good are the grounds? make sure they adequate especially if the battery is relocated.
jdmprelude10's Avatar
New User
I am having the same problem. Did you try new connectors for the battery terminal and check your spark
Old May 10, 2009 | 06:11 PM
Scheizty's Avatar
It fires as it turns, just too slowly to get it to idle speed. I cleaned the grounds, even tried different ground wires. No luck there either.
Old May 10, 2009 | 07:25 PM
wunfstgsr's Avatar
Loved
Community Favorite
maybe the map sensor is switched with iacv or your tps is off calibration. or bad spark wires!
Old May 10, 2009 | 07:29 PM
Muckman's Avatar
Moderator in Chief
With the spark plugs out and out of gear you should be able to crank over the engine by hand. Do that to make sure something isnt restricting rotation.
Old May 10, 2009 | 08:49 PM
Scheizty's Avatar
I can turn it over with a wrench. There is the usual resistance from the cam lobes, but aside that, it turns nicely. Has anyone had this problem with a newly built motor?
Old May 14, 2009 | 07:10 PM
Scheizty's Avatar
bump. still having this issue. Ran a new battery and starter, got a little faster crank, and about 25psi of oil pressure, but it won't run.
Old May 14, 2009 | 08:40 PM
SilverEk3dr's Avatar
U didnt foul your plugs out while trying all of this did you? Bad gas? No spark? No injector pulse?
Old May 14, 2009 | 08:59 PM
Scheizty's Avatar
3rd set of plugs. I checked spark, grounded the plugs to a ratchet on the valve cover, 4 were ok. fuel is good, rail pressure is clean, ~44psi.
Old May 14, 2009 | 09:23 PM
boostedb20z's Avatar
i had the same problem and the starter checked out good but i swaped for a used one my friend had and it ran great
Old May 15, 2009 | 05:15 PM
iaem1's Avatar
i had same problem on newly built motor.. turn out to be the rod bearings didn't have enough clearance . so it had alot of drag while cranking.
Old Jun 7, 2009 | 05:09 PM
willpower102's Avatar
where are these located? are the connectors the same? Could you post a picture or detail so I know if i have these switched?
Bump because i have the exact same problem.
All i did was swap all the good parts on my blown motor to a used motor that supposedly was good.
Turns freely
Timing belt is good and dead on.
Firing order is correct. Cap and button are new.
It's getting fuel (how do i check the pressure?)
All 4 plugs are sparking.
Starter worked fine when on my old motor.
civic=goodgasmileage
Honda Civic (2001 - 2005)
Jul 13, 2008 06:25 PM
GarageAlchemist
Feb 24, 2006 10:57 AM
sniperslayer
Dec 25, 2005 06:14 PM
97H22
May 1, 2003 09:10 AM
