Slick size for high hp...
Old Feb 24, 2003 | 01:05 PM
XES's Avatar
XES
Default Slick size for high hp...
After completing many searches, I am still not clear on what slick size I should be running.
To date I have been using a M/T 22x8x15 on my stock 15x6.5" wheels. I am constantly spinning the tires in 1st and 2nd...and am need of a slick/wheel upgrade.
I have access to multiple transmission/final drive setups, so please don't make advice based on mph or gearing. (I will take care of the gearing, etc.).
All I need to know is which size slick I should be running...and what will hold up to 500+ whp and give me the best traction.
I would appreciate 2 options:
1 with stock fenders in place (which can be rolled a little) and,
1 with severe fender modifications...
ps. 4th gen prelude chassis
Thanks
Old Feb 24, 2003 | 02:14 PM
DLB1994's Avatar
Default Re: Slick size for high hp... (XES)
i would try 26-8.5-15's if you cant fit a 13inch wheel
Old Feb 24, 2003 | 02:45 PM
paulzy's Avatar
Default Re: Slick size for high hp... (DLB1994)
Old Feb 24, 2003 | 03:07 PM
ExospeedAMcrx's Avatar
Default Re: Slick size for high hp... (Paul_Vang)
i dont believe you can fit the 13" wheel on a prelude brake setup.
with 15", you can go with a 24.5x8.5x15 setup.
will clear stock fenders.
with 1 piece front end or modified fenders, you can fit a 26x8x15
Old Feb 24, 2003 | 06:28 PM
XES's Avatar
XES
Default Re: Slick size for high hp... (exospeedAMcrx)
No, 13" won't go. And yes, I was thinking about either the 24.5x8.5, the 26x8.5 or the 26x10. I think both the 24.5x8.5 & 26x8.5 will still fit on the stock 6.5" rim, but I'm not sure whether i'll still have traction problems running the 24.5's.
Anybody have any experience with these slick sizes? Will I spin them with the 500+ whp?
Old Feb 24, 2003 | 06:35 PM
93LSivic's Avatar
I would not advise the 26x10. They are much too wide. I would do the new 25" slicks, if they are available in 15"--i know 13" but not sure on 15. Exospeed should be able to help you further on this, he sells a lot of slicks.
Old Feb 25, 2003 | 09:13 AM
XES's Avatar
XES
Default Re: Slick size for high hp... (93LSivic)
Anyone know if a 26x8.5 will fit in the stock wheelwell? I'm pretty sure the height will (cause I have run some 215/65/15's - junk winter tires) before...but the 8.5 could be pushing it...
Old Feb 25, 2003 | 10:53 PM
Kwuaymaikrup's Avatar
I don't know much about this myself but I'm sure if you asked over at the drag racing forum you will find your answer. I always see similar posts to this over ther. HTH.
-Ryan
Old Feb 26, 2003 | 12:06 AM
XES's Avatar
XES
Default Re: Slick size for high hp... (Kwuaymaikrup)
-Ryan
Ya...no luck over there, so I figure I'd probe the brains of the other hp cars on the Forced Induction site...
Old Feb 26, 2003 | 07:13 AM
h0mesk1let's Avatar
I dont know what your goals are, but just as a reminder, I believe the Prelude S's front brakes would allow you to clear 13" slicks. I know that atleast 14" rims fit, not sure about 13". Just something to look into if you REALLY wanted a smaller rim.
Old Feb 26, 2003 | 07:22 AM
Boostfed's Avatar
New User
Default Re: Slick size for high hp... (h0mesk1let)
[QUOTE]
I know that my Lensos would not fit on a 93 Prelude VTEC with stock brakes for FYI. We tried on Brandon's car, no dice!
Old Feb 26, 2003 | 07:27 AM
XES's Avatar
XES
Yes...as mentioned earlier I will be running 15" rims. That will not change. What I am looking for input on is tire size.
As for goals...my goal is to no spin 1st through 3rd on slicks. If 26x8.5" will let me do that...then those are the tire for me; if not then I will have to go bigger! We'll let the timeslips do the rest of the talking...
z6hatchboy
Jan 1, 2009 05:22 PM
kornerk12
Dec 8, 2006 08:42 AM
SpoolnG2
Aug 25, 2003 11:31 AM
XES
Feb 26, 2003 12:04 AM
98Psi ITR
Feb 24, 2003 10:56 AM
