What slick size/Rim size/ offset to get?
Old Aug 25, 2003 | 09:01 AM
SpoolnG2's Avatar
Default What slick size/Rim size/ offset to get?
I need to know what size slicks to get, and what size will fit in my wheel well. I have a 92 integra that will be pushing somewhere between 400-500 whp. I have a cable GSR trans with gearing as such 1st-3.307 2nd-2.105 3rd-1.458 4th-1.107 FD-4.40. I will be revving to about 9200rpm. Thanks guys. I'm lookin to run low 11's to high 10's.
Old Aug 25, 2003 | 09:03 AM
DaveF's Avatar
Default Re: What slick size/Rim size/ offset to get? (SpoolnG2)
my opinion
24.5x8.5x13
or 25x8x13
get a set of 13 inch bogarts or weld wheels to mount them on.
dont forget extended wheel studs.
Old Aug 25, 2003 | 09:07 AM
SpoolnG2's Avatar
Default Re: What slick size/Rim size/ offset to get? (2.2Lcivic)
extended ARP wheel studs are on the way. and i'm prally gonna get Weld rims. do i want a 13inch rim or 15? and how big of a slick will even fit in my wheel well?
Old Aug 25, 2003 | 09:14 AM
DaveF's Avatar
i would go with a 13 inch wheel unless you eventually plan on going to 26's or even 28's.....the 13 inch gives you more sidewall to play with.
i bet if ya jacked up the car pretty high you could barely fit a 26. but you should be able to fit a 25 with no problems.
Old Aug 25, 2003 | 11:31 AM
SpoolnG2's Avatar
a 13 inch rim will fit no problem with a stock rotor? how wide can i go? i was thinkin about like a 9.2. which would be better 25x9x13 or 25x9x15 i don't need a specific offset or anything?
danwv
Honda Fit
Mar 22, 2019 02:29 PM
z6hatchboy
Jan 1, 2009 05:22 PM
flat-blk-HB
Oct 25, 2004 06:58 PM
Islandboy
Mar 28, 2004 06:47 PM
SpoolnG2
Aug 25, 2003 11:34 AM
