sleeves a little low.
Old Feb 21, 2005 | 09:50 PM
808b18c1boosted's Avatar
Default sleeves a little low.
On my rs block one of the sleeves is a little low. Like not super low but i can feel the slight difference in height with my finger nail. There is also a slight gap between the sleeve but not that major do you guys think that the head gasket will still seal. thanks
Old Feb 21, 2005 | 10:21 PM
PrecisionH23a's Avatar
Default Re: sleeves a little low. (808b18c1boosted)
I would send the block back to who did it and have it checked out. If you can catch your fingernail on it, you are probably 2-3 thou too low.
Old Feb 21, 2005 | 10:38 PM
Default Re: sleeves a little low. (PrecisionH23a)
I hate shipping **** from Hawaiil. It will cost like 250 bucks so maybee a mahine shop can fix it?
Old Feb 22, 2005 | 12:33 AM
hondaapi's Avatar
As far as I know, the sleeves shall be 0.003 - 0.005 inch higher than the rest of the deck. Flat is the maximum that should be accepted to make sure that everything seals right. Hope it helps you.
Greetings from Germany
Kevin
Old Feb 22, 2005 | 06:23 AM
NJIN BUILDR's Avatar
You could have a local shop deck the block flat and give it a shot.A sleeve that is 1 or 2 thousands below the rest is most likely going to leak.
Glenn
Old Feb 22, 2005 | 06:33 AM
earl's Avatar
Default Re: sleeves a little low. (NJIN BUILDR)
Good advice, just surface it flat. You don't need the step for sealing if everything is flat. Jut be aware that if they drop once, they can drop again.
Old Feb 22, 2005 | 07:08 AM
hondaapi's Avatar
Default Re: sleeves a little low. (earl)
Let´s turn the question around. What is the max high for the step when the sleeves are higher than the rest of the block? What do you believe for maximum step high to make it not leaking?
Kevin
Old Feb 22, 2005 | 07:57 AM
PrettyLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">Good advice, just surface it flat. You don't need the step for sealing if everything is flat. Jut be aware that if they drop once, they can drop again.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">I would send the block back to who did it and have it checked out. If you can catch your fingernail on it, you are probably 2-3 thou too low.</TD></TR></TABLE>
eGosKar
Dec 15, 2011 08:57 PM
integraboosted
Oct 22, 2006 06:22 AM
brokeHonda
10
Oct 19, 2005 04:22 PM
VNTEC
Dec 22, 2003 12:46 PM
98Psi ITR
Mar 27, 2003 10:02 AM
