sleeveing engine
Old Jan 6, 2006 | 08:45 AM
92 CIVIC HATCH VX's Avatar
Default sleeving engine
ok my block is hot tanked and alined hones since it spun a bearing on the mains.
it's time to sleeve now i got a h22 closed deck and it looks like you bore the old sleeve out leave a divit at the bottom for the new sleeve to rest on. Then i gues i heat the block up with a torch to about 250ish and drop the new sleeves.
if this is correct what sleeves are good for boost on a h22 closed deck.
I was thinking dartons iron inserts or some small block chevy sleeves???
Modified by 92 CIVIC HATCH VX at 5:29 PM 2/6/2006
Old Jan 6, 2006 | 09:50 AM
tgreaves's Avatar
Default Re: sleeveing engine (92 CIVIC HATCH VX)
Umm.. Your joking right?
Old Jan 6, 2006 | 09:56 AM
Default Re: sleeveing engine (tgreaves)
about what?
Old Jan 6, 2006 | 09:57 AM
tgreaves's Avatar
About sleeving an engine with a torch..
Old Jan 6, 2006 | 09:59 AM
what else can you use?
Old Jan 6, 2006 | 10:00 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92 CIVIC HATCH VX &raquo;</TD></TR><TR><TD CLASS="quote">what else can you use?</TD></TR></TABLE>
A machine shop with an skilled machinst..
sorry never sleeved before but i'm going do not matter what. i want to learn
Old Jan 6, 2006 | 10:02 AM
tgreaves's Avatar
errr... ok.... Well there are directions on dartons site, and they suggest that you use a CNC machine on the block(everyone has those in their garage)..
Old Jan 6, 2006 | 10:03 AM
FATBOYeg6's Avatar
if your really set on doing your own sleeves, please dont do it with a torch. why do you want to re-sleeve it your self actually?
Old Jan 6, 2006 | 10:04 AM
tgreaves's Avatar
Default Re: sleeveing engine (ninefivehatch)
I asked EARL to join the topic.. He is a sleever and will explain the process.....and then tell you not to do it..
no my neighbors Matt driskell from driskell racing and he's helping me abit
Old Jan 6, 2006 | 10:05 AM
yeah i talked to earl about it before
Old Jan 6, 2006 | 10:06 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92 CIVIC HATCH VX &raquo;</TD></TR><TR><TD CLASS="quote">no my neighbors Matt driskell from driskell racing and he's helping me abit</TD></TR></TABLE>
Ok.. So he is a trained sleever then right..
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92 CIVIC HATCH VX &raquo;</TD></TR><TR><TD CLASS="quote">yeah i talked to earl about it before</TD></TR></TABLE>
AND EARL TOLD YOU TO USE A TORCH AND DO IT YOURSELF?
i'm guessing you could use some type of oven to heat you block up? instead of a torch now i know everyone has a oven. But i don't think my roommates would be happy.
Old Jan 6, 2006 | 10:08 AM
yeah he builds engine's and no earl never said to use a torch. thats what i was thinking, i guess i'm wrong on that.
Old Jan 6, 2006 | 10:14 AM
would the darton inserts be a good choice on a closed deck i think they were like 175.00 dollars
Old Jan 6, 2006 | 10:15 AM
yeah he builds engine's and no eral never said use a torch that what i was thinking i guess i'm wrong on that.
Old Jan 6, 2006 | 10:18 AM
tgreaves's Avatar
And how do you plan on cutting the old sleeves out????
andysila's Avatar
if you want quality work..send the block to someone whos done it a million times
Benson
remember, you never want to cheap out when it comes to stuff like this... dont go to sears and buy a torch just cause you want to have the "successfull" feeling..
Old Jan 6, 2006 | 10:21 AM
what about the darton iron replacement sleeve? has anyone used it on a closed deck before?
tgreaves's Avatar
Watch this video..
http://www.erlperformance.com/...G.mpg
Old Jan 6, 2006 | 10:24 AM
andysila's Avatar
https://honda-tech.com/zerothread?id=565375
This is the best thread for sleeving and explanations...
Old Jan 6, 2006 | 10:36 AM
Default Re: (andysila)
yeah the guys from ohio i seen that vid before matt has the same equipment but not the aline honer that those guys have in the video.
it a nice vid to see the technical aspects fo the bore and honing process.
and i guess you hot tank the temp and then freeze the sleeves.
do all sleeves need that beveled edge for sealing?
Old Jan 6, 2006 | 10:41 AM
tgreaves's Avatar
Default Re: (92 CIVIC HATCH VX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92 CIVIC HATCH VX &raquo;</TD></TR><TR><TD CLASS="quote">yeah the guys from ohio i seen that vid before matt has the same equipment but not the aline honer that those guys have in the video.
do all sleeves need that beveled edge for sealing?</TD></TR></TABLE>
Hmm.. Matt has some of the same equipment and doesnt know how to sleeve.. I would call Darton then... And my parting note - Dont do it yourself..
