skunk2 intake manifold on b18b question.
im just finishing up my skunk2 intake manifold installation on my LS and im having a little problem. there's a nipple on the back of the manifold right next to the big coolant line that i don't know where to run a line from... any suggestions?
Re: skunk2 intake manifold on b18b question. (sung)
Sung why didn't you just ask me on AIM. Just go to the Auto Partsstore in the Help! section and get a pack of black nipple plugs that is what I did with mine when I had a Skunk2 before. ood luck with yours and Brandon's car! Tomorrow photoshoot?
If you have a water cooled center section on your turbo, you can run the line to that and then into your throttle body water lines.
Just wanted to give you a suggestion for the future .
Re: skunk2 intake manifold on b18b question. (LiLOtaku)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LiLOtaku »</TD></TR><TR><TD CLASS="quote">If you have a water cooled center section on your turbo, you can run the line to that and then into your throttle body water lines.
Just wanted to give you a suggestion for the future .</TD></TR></TABLE>
Good idea I wonder if pressure will be enough there though
Re: skunk2 intake manifold on b18b question. (Boostfed)
Don't need much pressure, that's basically where most people tee from to get a water source for their chra..
jkalex05
08-23-2009 06:01 PM
obd2gsr
10-23-2003 10:19 AM
