Skunk 2 Pro 1 question...
Old Feb 5, 2009 | 08:06 AM
Ls_dx's Avatar
Default Skunk 2 Pro 1 question...
I cant afford the motor that I want to put together right now for this season.. So Im gonna piece back together my B16. I have a Un ported GSR head Im gonna put these PRO1's and matching Ti retainers and springs into.. I should notice a difference over the GSR cams I had been using shouldnt I? I have seen the T1 chart where they made +150hp at 40lb, Im only going to be putting about 20 Lb to this block.. Comments ideas or thoughts?
Old Feb 5, 2009 | 08:41 AM
BlakeJ53's Avatar
Default Re: Skunk 2 Pro 1 question...
If you dont have a Huge turbo like just get ITR's. I had a 60-1 t3 with a 63 ar exhaust housing and a stage3 wheel it was restricing the cams. So I am upgrading to a 82 ar exhaust housing and a stage 5 wheel with a GT35R compressor housung and wheel.
Old Feb 5, 2009 | 08:54 AM
tegman23's Avatar
How much power are you trying to make? If your only trying to make 300-400whp i think itr cams are going to work fine..Pro 1s seemed to be used for the guys going for my hp from what I have read
Old Feb 5, 2009 | 08:55 AM
Ls_dx's Avatar
Yeah... well I already have the Pro1's and the springs are going into the head today so hopefully the Gt3076R that I have dont hold the Pro1's back....
Old Feb 5, 2009 | 09:20 AM
mangina's Avatar
here is my dyno with same turbo at 15psi.
I compared it to a 60-1 from a friend mine had alot more midrange power
with pro1's
Old Feb 5, 2009 | 09:31 AM
Ls_dx's Avatar
Thanks for the dyno sheet. I put down 302Whp with gsr cams and 12lbs of boost with a different cylinder head..
Old Feb 5, 2009 | 09:36 AM
mangina's Avatar
my head just has a 3 angle valve job and supertech valves, springs, retainers.
its also a 2.0l
Old Feb 5, 2009 | 09:40 AM
sp00led's Avatar
I'd find the quote from Jeff Evans on this but search is down. He doesn't recommend running pro1s on anything smaller then the gt35. For the GT30R the Tuner1s will preform best and make about 10-20whp more then the ITRs.
If you decided to run the pro1s, make sure you degree them in otherwise you won't get them to idle for crap. That was another reason I sold my pro1s to pickup the tuner1s.
Old Feb 5, 2009 | 09:59 AM
Ls_dx's Avatar
Wellll I dont really have the option to use tuner1 or itr's i have these Pro1s sitting on the shelf.. and im wanting to use them cus they are paid for
Old Feb 5, 2009 | 10:05 AM
narfdanarf's Avatar
Well if you are going to use them regardless of what anyone tells you, why did you make this thread?
Old Feb 5, 2009 | 11:31 AM
Ls_dx's Avatar
Just seeing if there is going to be a difference... or if its a BAD idea.. did you READ my OP??
Old Feb 5, 2009 | 11:35 AM
Ls_dx's Avatar
go nit pick elsewhere
Old Feb 5, 2009 | 03:23 PM
96 GSR-T's Avatar
I think the manifold type matters just as much if not more than the size of the turbo being used. Log manifolds and cams larger than ITR do not go well, especially on H22's from what I have learned. To run the large cams (pro-1/tuner 2's) you need to have good flow and velocity (low backpressure) from the head to the turbo (ramhorn, topmount) for the large NA cams to make power, and inlinepro type manifolds and logs do not flow what a good tubular EL can.
Old Feb 5, 2009 | 04:33 PM
Ls_dx's Avatar
I just picked mt up a really nice RLD ram horn ...
Old Feb 5, 2009 | 04:47 PM
ayos ctr_hatch's Avatar
can I use the pro 1s with skunk tuner springs?
Old Feb 6, 2009 | 07:04 AM
boostedeg6-1's Avatar
I wouldnt advise running the pro1's on tuner springs, on skunk2's website it says pro series springs required to run them
Old Feb 6, 2009 | 07:09 AM
PrecisionH23a's Avatar
ITR cams, 83mm b18c1, sc61e
Run 2 - GSR Cams
Run 2- ITR cams untuned
Run 12 - ITR Cams tuned
Old Feb 6, 2009 | 12:14 PM
Ls_dx's Avatar
Nice step up from the gsr cams to the ITR's
x275radial
Feb 17, 2013 08:56 AM
attack666
Mar 10, 2010 09:17 PM
tegra2G
Jun 16, 2008 03:30 PM
pane93civhb
Mar 18, 2008 05:00 PM
navin
Jun 19, 2003 06:34 PM
