since NOS is only Temporary
Old May 30, 2002 | 09:37 PM
freakie's Avatar
Default since NOS is only Temporary
for all those ******* picky *****, N2O is only a temporary thing, until it runs out.
What I want to know is how do u get the extra fuel into the engine for the times that you are using the N2O, and to not use that extra fuel when your not using the N2O..
basically, how do u adjust fuel for only temporary needs?
Old May 30, 2002 | 11:05 PM
dirtySOHC's's Avatar
Default Re: since NOS is only Temporary (freakie)
run a wet kit.......
Old May 30, 2002 | 11:07 PM
R-1303's Avatar
Default Re: since NOS is only Temporary (dirtySOHC's)
zex i think works fine...run by there own ecu..but i don't know about under boost situations..just my opion
Old May 30, 2002 | 11:32 PM
01geeser's Avatar
New User
Default Re: since NOS is only Temporary (R-1303)
only time when extra fuel+nitrous is used is when you hit the switch. when ur n2o isnt activated then no extra fuel is used.
Old May 31, 2002 | 12:43 AM
Reverend's Avatar
What he said - there will be two pills going into the intake -- the nos, and the fuel, these two amounts of extra stuff in your intake charge will equal the actual wet shot you are using.
D15Bbigred
Nov 11, 2006 06:33 AM
DOHC VTEC EG
Feb 5, 2004 05:33 PM
Defiantpeformance
Oct 14, 2003 11:26 PM
xxplosif1
Apr 21, 2002 07:06 AM
