simple injector question
Old Jun 27, 2004 | 10:22 PM
StrangerWitCandy's Avatar
Default simple injector question
do i need new injectors to run 6-7psi on a stock B18C w/ a T3/T4? if so, what how much flow should i need? i know its simple, but i couldent find the info searching. thanks for any help!
Old Jun 27, 2004 | 10:36 PM
jdhybrid's Avatar
Default Re: simple injector question (StrangerWitCandy)
no factory injectors can handle up to 250 hp
Old Jun 28, 2004 | 07:43 AM
Default Re: simple injector question (jdhybrid)
thanks jd
but can anyone else give me a bit more information?
Old Jun 28, 2004 | 08:17 AM
MachAF's Avatar
you can run stock injectors, but you have to increase the fuel pressure by running an FMU.
Stock injectors are runing 92% duty cycle at 8000rpm.
If you plan on running some type of standalone ECU (AEM,uberdata) then you will need to get bigger injectors.
I would not recommend going to FMU/stock injector route.
Old Jun 28, 2004 | 09:28 AM
Default Re: simple injector question (MachAF)
ohh, i forgot to mention im running hondata... so i guess that means bigger injectors.
what flow/type should i look for?
thanks for the help!
Old Jun 28, 2004 | 11:41 AM
MachAF's Avatar
injector size will depend upon how much horse power you are running.
You'll want to get saturated injectors (high impedance)
you can also get peak-and-hold injectors but you'll need a resistor box.
Old Jul 2, 2004 | 09:04 PM
so im shooting for 250whp (i may have to run a bit more boost than 7psi)... according to some equations ive found that setup would need 550's, is that true? or would DSM 450's do the job?
89hybrid
Sep 25, 2014 10:40 PM
2000siturboR
Oct 7, 2008 09:27 AM
97civicDX-R
May 16, 2007 07:36 PM
B16A1-EF9
Jun 24, 2004 03:32 AM
kaneda3
Dec 30, 2002 12:18 PM
