Injector help
Old Sep 11, 2014 | 12:43 AM
89hybrid's Avatar
Default Injector help
Hello all
As stated in the title. I need help with figuring out what injectors to run. I have an 89 civic hatch with a z6. It will have a chipped pm6 ecu with a greddy tdo4h. I believe that's right it's an older kit. I do not plan to run over 10lbs. Of boost since the bottom end is still stock. I appreciate any and all help.
Thanks
Stacy
Old Sep 11, 2014 | 05:44 AM
Schister66's Avatar
Man U FTW
Default Re: Injector help
Since you're not going to make more than 220-240whp on a stock D series before the rods give up, we will use the higher end of that range as your power goal. As a simple rule of thumb, you can use 6cc per whp to size injectors. The equation is as follows (for pump gas).
240whp x 6cc/whp = 1440cc total injector flow
1440 / 4 injectors = 360cc injectors (at a minimum)
This basically means that if you can find a set of 440-550cc injectors (or even DSM 450s), you will have plenty of injector for your power goals.
Old Sep 11, 2014 | 07:37 AM
89hybrid's Avatar
Ok thanks. What type of injectors are DSM are they peak hold or saturation. Will I need a resister box ?
Thanks
Stacy
Old Sep 11, 2014 | 12:21 PM
Schister66's Avatar
Man U FTW
They are peak and hold injectors which, for our cars, do require a resistor box.
There are threads regarding the wiring and install of the resistor box in the Forced Induction FAQ (top of the FI Forum). Here is one example...not sure if the pictures will still work since its so old
https://honda-tech.com/forced-induct...adband-517274/
Old Sep 12, 2014 | 07:51 AM
89hybrid's Avatar
Ok I'll check it out thanks
Old Sep 23, 2014 | 11:26 PM
89hybrid's Avatar
Another question if I may. This is a z6 swap into an 89 hatch. So I am running a 91 pm6 ecu and a 91 dizzy. Do I still need resister box for DSM injectors. Thanks
Old Sep 23, 2014 | 11:36 PM
wantboost's Avatar
Who is Mr Robot?
yes, IIRC all honda injectors are/were saturated low resistance injectors... at least on the b and d motors as well as the older f and h motors
Old Sep 24, 2014 | 12:02 AM
m4xwellmurd3r's Avatar
I am shocked by you wantboost lol. As far as b series go (I belive this is true for d series too) only obd0 cars were peak and hold low impedance injectors.
Post obd0 are saturated high impedance injectors.
As far as I can remember, h series and f series injectors are peak hold low impedance for the accords and preludes, but some may have been high impedance too (ran into this issue with a friends f2b swap)
Old Sep 24, 2014 | 02:21 PM
wantboost's Avatar
Who is Mr Robot?
There's so much car info in my head I think I'm starting to mix **** together lol.
Old Sep 24, 2014 | 05:47 PM
You know how I solved that problem? My brain activley dumps any information not relevant to car knowledge im trying to obtain. My gf thinks im some sort of retard because I have to go back and ask her what I was supposed to do not even 2 minutes after she told me.
Like that episode of sponge bob where he has to become a high class waiter and his brain is all like "forget everything except fine dining and breathing" so his brain just dumps out everything.
Yeah, thats how my brain works.
(Note:I have kids, lots of spongebob cartoons in this house lmao)
Old Sep 25, 2014 | 10:40 PM
wantboost's Avatar
Who is Mr Robot?
I'm the same way, if it isn't car related I'll forget even the most basic of things. Lots of "what was I supposed to do" going on... Of course most of that is from my traumatic brain injury from my bad car accident. It's getting better though.. 2-4 years ago I couldn't even remember the last few hours :/
prelude2121
Oct 29, 2010 02:40 PM
swt_666
May 16, 2007 09:33 PM
97civicDX-R
May 16, 2007 07:36 PM
ludetech
Oct 15, 2004 09:09 AM
StrangerWitCandy
Jul 2, 2004 09:04 PM
