Should i upgrade my intercooler?????
Old Sep 12, 2006 | 05:56 AM
JDM97R's Avatar
Default Should i upgrade my intercooler?????
Hi guys, i have a jdm b18 turbo on my ef ( see my sig) .
I'm running 18 psi with the drag gen 3 turbo kit.The engines is making 400whp.What should i first upgrade?
I'm thinking to change the intercooler or the inlet manifold and throttle body.
What do you guys suggest?The engine has stock sleeves so i 'll be not going more than 23 psi.I use my car at the strip only....
Thanks
Modified by JDM97R at 4:22 PM 9/12/2006
Old Sep 12, 2006 | 07:20 AM
BOOSTED RIVAL's Avatar
Default Re: Should i upgrade my intercooler????? (JDM97R)
If you still running your drag intercooler then upgrade that first. 2 inche inlets on the drag intercooler is kinds of small. and are you still running the drag T3 T4 turbo, if you are that turbo is kind of small too so it will create alot of heat if you are boosting high so a bigger intercooler is a must.
Old Sep 12, 2006 | 10:49 AM
JDM97R's Avatar
Default Re: Should i upgrade my intercooler????? (BOOSTED RIVAL)
Yes i'm with the drag gen turbo, so my first upgrade will be the inter cooler and then the turbo.Which size do i have to make the intercooler?
Thanks
Old Sep 12, 2006 | 10:58 AM
You could get a Precision intercooler. The 600-hp or 750-hp
Old Sep 12, 2006 | 01:50 PM
dpetro1's Avatar
why not log some iats before spending money on a new intercooler??? even though i think 400whp is probably the limit for the drag IC.
Old Sep 12, 2006 | 03:11 PM
JDM97R's Avatar
Default Re: Should i upgrade my intercooler????? (dpetro1)
Thanks guys,i'm going to replace my i/c first .After that i'll try to replace the turbo.I was thinking of gt35r or gt40r.What do you recommend?
Old Sep 12, 2006 | 03:23 PM
sc4dr's Avatar
I here great stuff about the gt3076
Old Sep 12, 2006 | 04:00 PM
mra4886's Avatar
if you are running around 400whp get the percission 600 or 750 and get 3in ic piping.
Old Sep 12, 2006 | 04:01 PM
mra4886's Avatar
Default Re: (mra4886)
then get the victor x intake mani and get a tb. then get the turbo.
Old Sep 13, 2006 | 02:56 AM
JDM97R's Avatar
Thanks for all your help
B-Hatchie
Jul 6, 2005 09:21 AM
2000turbosi
Jun 22, 2004 06:42 PM
7808
Mar 18, 2004 05:12 AM
ramz7887
Apr 24, 2003 12:11 PM
Rah Rah
Feb 20, 2003 12:10 PM
