Should i run synthetic?
Old Mar 17, 2002 | 07:35 PM
Chip398193's Avatar
New User
Default Should i run synthetic?
i have a 95 ls integra i will be boosting soon (drag 3). it has 70k miles on it. should iu change to synthetic when the drag 3 kit goes on?
Old Mar 17, 2002 | 07:42 PM
Farnsrocket's Avatar
Default Re: Should i run synthetic? (Chip398193)
IMO you should always use synthetic.
Old Mar 17, 2002 | 11:21 PM
turbopanda's Avatar
Default Re: Should i run synthetic? (Farnsrocket)
i've always used synthetic, even before I had my turbo
Old Mar 17, 2002 | 11:28 PM
SIK IN DA HED's Avatar
New User
Default Re: Should i run synthetic? (nathan's boosted civic)
i dont think it really matters as much what oil type you use. synthetic, synthetic blend, or just the regular oil... as long as you use a good brand name that you can trust. i used to use synthetic oil. since i change my oil every 2 weeks... i figured it would be cheaper to use regular oil like valvoline, castrol, or mobil.
Old Mar 17, 2002 | 11:39 PM
turbopanda's Avatar
Default Re: Should i run synthetic? (dlplayboy)
umm why do you change your oil every 2 weeks? is it something you enjoy doing??
Old Mar 18, 2002 | 12:07 AM
New User
uhmmm i commute 2 hours to school and back. i usually kick it at cities 30-60 mintues away. so of course... i need to change it frequently. after 2 weeks, my oil is pretty dirty.
Old Mar 18, 2002 | 10:03 AM
turbopanda's Avatar
I do that too.. hmm.. maybe I should change it every 2 weeks too My oil changes tend to happen every 4-6 weeks, depending on how the engine's running.. if its starting to feel a little slower than normal, thats when i get the oil changed and get my mechanic to adjust my valves and do a leakdown
Old Mar 18, 2002 | 10:58 AM
ATurboCivic2NV's Avatar
damn that is nuts!
Old Mar 18, 2002 | 11:31 AM
bQQsted hybrid's Avatar
Default Re: Should i run synthetic? (ATurboCivic2NV)
changing your oil every 2 weeks is frikken ridiculous.
Old Mar 18, 2002 | 11:50 AM
Default Re: Should i run synthetic? (bQQsted hybrid)
How many miles do you put on it in 2 weeks?
Old Mar 18, 2002 | 12:05 PM
B20LS-T's Avatar
New User
Hmmm...actually youre not supposed to switch over to synthetic oil after you have been driving your car on regular oil for more than 1000 miles, the only time you can switch over is if you buy the car new.
Old Mar 18, 2002 | 12:09 PM
Default Re: Should i run synthetic? (B20LS-T)
That's wrong.....you can switch over anytime.
Old Mar 18, 2002 | 12:32 PM
lucas569's Avatar
can you expound on this?
Old Mar 18, 2002 | 12:44 PM
New User
moderator: please forward this to the newbie section. hahah just kidding.
dont agree with you on this man.
and YES, although i dont usually change it every 2 weeks like i used to... i still try to do it occassionally. i drive around 1,000 miles every two weeks. so what if i were to change my oil every two weeks? nothing wrong with keeping a clean batch of oil in the oil pan. sheesh!
Old Mar 18, 2002 | 12:49 PM
VTC_CiViC's Avatar
Actually, I too heard it's reccomended not to switch to synthetic after a certain amount of miles, but it's more like 70k+ miles. By that time, the amount of wear-in on the seals and rings is somewhat more than would occur with a much thinner oil (synthetic), therefore leading to mild oil burn. I guess usuing a thicker (15w-50) synthetic oil could work too though right? Make sense? I know my Civic has over 100k miles and doesn't burn oil, but then I've been usuing Mobil 1 since it's very first change at 2200 miles and every 8k miles there after.
Old Mar 18, 2002 | 04:06 PM
B20LS-T's Avatar
New User
No no no, you read it all wrong What I was trying to say is that after your engine breaks in (second oil change) is the only GOOD time to change over to synthetic. I said nothing about how often you change your oil, if you have time to change it every week then to you! Sure you can use synthetic oil anytime you like, but i heard after a certain mileage (most likely break in period) is the best time, if you change over after like 30,000 miles, I heard it puts more stress on your bearings and seals, because it was run on thicker oil. I will try and research this more, but thats what I was told. Synthetic is definately better for turbos though.
SiYouLater
Acura TSX
Jul 27, 2007 02:36 PM
mfisher1967
Honda Civic (2006 - 2015)
125
Jun 5, 2007 11:41 AM
v0lcom27
22
Jul 13, 2005 07:30 AM
RacerXintegra2k
Sep 12, 2002 11:34 PM
Mike D
Jun 23, 2001 07:26 PM
