She's almost done..:)
Old Jan 1, 2003 | 04:12 PM
CzanSOHC's Avatar
Default My setup :)
Here a few pics of my current setup....
Enjoy
[Modified by CzanSOHC, 5:21 PM 1/1/2003]
[Modified by CzanSOHC, 5:34 PM 1/1/2003]
Old Jan 1, 2003 | 04:20 PM
Smashback's Avatar
Default Re: She's almost done..:) (CzanSOHC)
Use a thin screw driver to pry the pan in a few spots, then it will pop right off. There should be sealant on the sharp bends around the crank area if that makes any sense...
Look at that fancy TRUST vacuum hose!!! Tiiiiiite!!!
Hey, buy my ported head or you'll never make any power
I promise I'll give you those AFC settings soon...been busy, out of town, etc. My motor should be here this week so I'll be forced to start work on the car again soon
Old Jan 1, 2003 | 04:23 PM
ImAcracker's Avatar
Loved
Default Re: My setup :) (CzanSOHC)
What king of manifold are you using?
Old Jan 1, 2003 | 04:26 PM
CzanSOHC's Avatar
Default Re: She's almost done..:) (Hatchblack)
Awesome man..i thought you had forgot about the AFC settings.. right now I have to draw back -48 at idle just to idle smooth....but the car seems to be running fine once I got my injectors and started the hack.. But i'm sure your setting's will help me out a lot more.
Haha...i would buy that head dude...but I figure I'm not going to dump much more into my pretty d16...i've seen the bseries light...but I'm gonna have fun w/ the d16 for about a year...or until my stock clutch burns out
Let me know how that swap goes
Old Jan 1, 2003 | 04:27 PM
CzanSOHC's Avatar
Default Re: My setup :) (ImAcracker)
It is a Max rev manifold.
Old Jan 1, 2003 | 05:01 PM
Honda4CX-T's Avatar
Nice progress CzanSOHC
........ I had to do my Water Pump, T-Belt & Oil Pump ... Blah blah blah !
( Oh, Well that's what winter is for ? )
Old Jan 1, 2003 | 05:44 PM
hatch101's Avatar
how bad is the turbo lag? what motor is it on? what is your whole set up? sorry about all of the questions. e-mail me if you want at loco_dude69@hotmail.com with the set up if you want. im going to boost a SOHC soon and i would LOVe to get more info on your set up.
Old Jan 1, 2003 | 05:51 PM
johnisenglish's Avatar
From when? My MaxRev Mani, and all the other's I've seen have the Wastegate port located right above the Turbo...
Old Jan 1, 2003 | 07:09 PM
FBP Si 2000's Avatar
Old Jan 1, 2003 | 07:19 PM
Farnsrocket's Avatar
Default Re: My setup :) (FBP Si 2000)
Looks great man!
Old Jan 1, 2003 | 07:31 PM
CzanSOHC's Avatar
Default Re: My setup :) (hatch101)
Couldn't tell you that yet man. it should not be that bad, it's a .50 trim, .50 A/R on the cold side, and .48 on the hot side. Should not be a bad spool time prolly around 3.5-4k.
d16y7 for now
check your email.
Old Jan 1, 2003 | 07:32 PM
CzanSOHC's Avatar
Default Re: My setup :) (Honda4CX-R)
So when is your stuff gonna be on?
Old Jan 1, 2003 | 07:33 PM
CzanSOHC's Avatar
Default Re: My setup :) (johnisenglish)
For some reason, i think D series ones have the flange for the wastegate here...i wish it was on the center though.
Old Jan 1, 2003 | 07:35 PM
CzanSOHC's Avatar
Default Re: My setup :) (Farnsrocket)
Looks great man!
You like that wastegate dump tube Jon
Dude, your car inspired me...i can't wait tell i get this finished!
Old Jan 1, 2003 | 07:42 PM
D-Man's Avatar
Your hood doesnt hit that wastegate? i know on my EF if it was mounted like that,id have to cut a hole in the hood to make that setup fit
[Modified by D-Man, 11:43 PM 1/1/2003]
Old Jan 1, 2003 | 07:45 PM
CzanSOHC's Avatar
Default Re: My setup :) (D-Man)
No, it doesn't hit at all. it's actullay just slightly over the vavle cover. It's a VIS CF hood though...and I don't have my stock one to compare.
Old Jan 1, 2003 | 08:52 PM
CzanSOHC's Avatar
Default Re: My setup :) (jerseykid609)
best of luck any hp numbers ?
Thanks....nope none yet....i'm just messing around w/ the d16...once it goes...Bseries is going in.
Old Jan 1, 2003 | 08:57 PM
Danger's Avatar
very nice good luck with your setup .
Old Jan 1, 2003 | 11:28 PM
T-sohctec's Avatar
AWESOME!
Very clean install. Is this in a hatch?
Old Jan 2, 2003 | 12:11 AM
JDEM1's Avatar
Default Re: My setup :) (T-sohctec)
nice.. lovin' the maxrev kits... hm.. your w/g clears the hood fine?... does anyone know if that same setup on a bseries would be any different?.. im hoping i dont have to use an elbow for the w/g...
Old Jan 2, 2003 | 12:24 AM
JDEM1's Avatar
Default Re: My setup :) (G_Force_Si)
oh and a couple other things, is that a custom dumptube?.. hahah wheres it lead to?.. and youre not planning on putting a filter on the turbo?...
Old Jan 2, 2003 | 03:39 AM
My Tial worked fine with my 95 Teg and MaxRev........no cutting.
Old Jan 2, 2003 | 08:36 AM
Honda4CX-T's Avatar
When I get back from bussines trip (end of JAN) .... Hopefully if I get all the piping welded when I get back, it will be a "cakewalk" .
Old Jan 2, 2003 | 08:47 AM
VTC_CiViC's Avatar
Very nice dude very nice! Time is ticking for me, just bought my first house and I get married in a month or so, so once I get everything squared away and I have the fincancial freedom I need, the boostless bastard get's built
Keep it up and show us some dyno numbers
You're running the hack right? make sure you show us A/F numbers as well I ran fine up to 12psi on the hack so you should be fine
Old Jan 2, 2003 | 09:41 AM
M.A.R.C.'s Avatar
nice work... btw... that valvecover looks nice. i gotta find out how to paint it like that
