Shaft Play..?
Old Jan 31, 2007 | 01:16 PM
CodyC142's Avatar
Default Shaft Play..?
My buddy is looking for a turbo for his ls.. so I was browsing around on here, and found a turbo from a GST for 75$. The guy says it has less than 1mm of shaft play. Is this something to cause major concern? How hard is it to correct the shaft? Is it expensive?
Thanks ALOT
Old Jan 31, 2007 | 01:56 PM
A.E Motoring's Avatar
Default Re: Shaft Play..? (CodyC142)
need to send it in to a shop, and have them rebuild it, and rebalance the turbo, usual charge for rebuilds around anywhere from 150+, not worth it if u ask me
Old Jan 31, 2007 | 03:53 PM
CodyC142's Avatar
Default Re: Shaft Play..? (Dual Cam Racing)
so 1mm of horzintal shaft play isnt allowable?
Old Jan 31, 2007 | 04:01 PM
im really not sure if its that bad, but it could get worse with time, im u cant be 75 bucks, give it a shot
Old Jan 31, 2007 | 04:30 PM
turbo boost's Avatar
isnt a lil shaft play normal ...up and down?
Old Jan 31, 2007 | 04:36 PM
CodyC142's Avatar
Default Re: Shaft Play..? (snowbunny)
this is horizontal.. the guy said it had no vertical play
Old Jan 31, 2007 | 04:38 PM
i thought vertical was ok...and side to side was bad?
Old Jan 31, 2007 | 04:47 PM
blueshark123's Avatar
I wouldnt even think about it
Old Jan 31, 2007 | 04:48 PM
CodyC142's Avatar
Default Re: (blueshark123)
as in buy is ASAP? or just forget about it?
Old Jan 31, 2007 | 08:16 PM
qfast817's Avatar
Default Re: (CodyC142)
75 is a lot i find them for 30 bucks all the time
Old Jan 31, 2007 | 09:13 PM
CRX_1.8T's Avatar
Default Re: (qfast817)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qfast817 &raquo;</TD></TR><TR><TD CLASS="quote">75 is a lot i find them for 30 bucks all the time</TD></TR></TABLE>
x2
I bought 2 complete turbo setups (oem) off of totaled DSM's in the local yard here for only $20 apiece.
I think the original poster can do much better, maybe even just buying a brand new one since they aren't too expensive really.
Old Feb 1, 2007 | 12:11 PM
CodyC142's Avatar
Default Re: (CRX_1.8T)
Ok, thank you guys for your help
Im just going to pass, and continue looking
ripperbone
Mar 27, 2006 06:30 PM
IntegraMastaz
Nov 16, 2005 09:28 PM
Bictorious
Aug 31, 2004 08:26 PM
Sohc Driver
Aug 18, 2003 09:46 AM
