shaft play in a KKK ballbearing turbo.
I just acquired a KKK ball bearing turbo, and there is shaftplay in it...Is this repairable....Do i just need a routine build up, or is there more things involved in bringing this turbo back up to spec? If i am too vague please tell me what other information you need to answer my question.
Khoi
Khoi
Re: shaft play in a KKK ballbearing turbo. (toolowsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toolowsol »</TD></TR><TR><TD CLASS="quote">how much shaft play?? all turbo's have some shaft play.... Also, is it side to side, or in and out?</TD></TR></TABLE>
both..however..the fins aren't touching or rubbing against anything..the shaft spins freely...no metal to metal contact anywhere
Khoi
Khoi
Re: shaft play in a KKK ballbearing turbo. (dragboy)
I am probably not going to run this turbo though....I might run a td05 16g turbo instead, because i already have the manifold and downpipe for it.....My plans for this turbo are to either rebuild it and sell it..or sell it as is...im trying to see what i need to do to put this turbo back to spec first however...
Khoi
Re: shaft play in a KKK ballbearing turbo. (Sohc Driver)
Send it to Majestic turbo in TX. KKK turbo's are notorious for taking a dump. They have a tendency to blow seals on quite a few VW and Audi's.
JUST2SPOOL
01-24-2006 05:12 PM
