SFP Manifold
Old 01-22-2008, 03:31 PM
BlakeJ53's Avatar
Default SFP Manifold
I just bought a SFP T4 Turbo manifold. It has a 38mm gate flange on it. I am worried that will be to small. Has anyone who runs this manifold have boost creep problems with a 38mm gate? I am looking to run 500 hp to 550 hp to the wheel on high boost. But only like 300hp on low boost. Thanks Jordan
Modified by BlakeJ53 at 4:20 PM 1/24/2008
Old 01-22-2008, 03:42 PM
jdm_vtec's Avatar
Default Re: SFP MANIFOLD (BlakeJ53)
ATPturbo sells a 38mm to 44mm vband adapter.. you could even go as far as taking it to a machine shop if you're that worried about it and just have a 44mm v-band welded
Old 01-23-2008, 05:13 PM
BlakeJ53's Avatar
I can weld it my self. I was just wondering who has changed it or if it even needs to be done.
Old 01-23-2008, 05:42 PM
DfwBB6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlakeJ53 &raquo;</TD></TR><TR><TD CLASS="quote">I can weld it my self. I was just wondering who has changed it or if it even needs to be done.</TD></TR></TABLE>
i have a SFP manifold converted to a 44mm. If you can weld or have a shop weld it on for ya that would be the best way to go.
Old 01-23-2008, 05:57 PM
b20vtech's Avatar
do u really need a bigger wastegate for higher HP application?
Old 01-23-2008, 06:05 PM
jaynmeli's Avatar
sorry not really info i just wanted to ask a quick question. does anyone know if sfp is still around? if so where are they? btw nice manifold
Old 01-23-2008, 06:16 PM
jdm_vtec's Avatar
Default Re: SFP MANIFOLD (DfwBB6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DfwBB6 &raquo;</TD></TR><TR><TD CLASS="quote">
nice job
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vtech &raquo;</TD></TR><TR><TD CLASS="quote">do u really need a bigger wastegate for higher HP application?</TD></TR></TABLE>
of course, especially if you're running a manifold with small runners.
Old 01-23-2008, 10:39 PM
BlakeJ53's Avatar
Did you just weld on a 44mm flange or did you replace the whole elbow?
Old 01-24-2008, 06:16 AM
DfwBB6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlakeJ53 &raquo;</TD></TR><TR><TD CLASS="quote">Did you just weld on a 44mm flange or did you replace the whole elbow?</TD></TR></TABLE>
just the 44mm flange was welded onto the existing elbow
IceySC
05-23-2007 07:40 PM
Ri5e
09-17-2004 05:27 AM
boostedcivichatchbacksi
04-09-2004 07:44 PM
yimmy
01-12-2004 08:32 AM
Alberto
01-10-2004 12:40 PM
Quick Reply: SFP Manifold
