SFP GSR 9psi 315hp?
SFP GSR 9psi 315hp?
What the F is that. I was checking out their site, since my manifold is SFP. and I came across their gallery which showed a GSR with their custom turbo kit. They claim they get 315whp from 9psi. Crap I thought that was high, my friend had a turbo gsr and he wasn't hittin 300 at 9psi. Is this possible or are they blowin smoke out peoples ***!?
Re: SFP GSR 9psi 315hp? (DC2R714)
If it was a built motor (I.E. high compression bigger displacement) with the right turbo its possible. My friend with a 2.0l b18b motor made 300whp at 10psi.
Re: SFP GSR 9psi 315hp? (newsense)
newsense hw much boost where u pushing when you made that pass and what do you think a 92-95civic coupe or h/b would do with a ls turbo or a b16a turbo in it because my friend is trying to do mid 12's
Re: SFP GSR 9psi 315hp? (94goldjungsr)
damn...that's sick!!! btw, do you know which internals were replaced? cams, valves, retainers, springs, pistons, rods, gaskets, etc.....???
Re: SFP GSR 9psi 315hp? (eagle2)
An LS with a turbo kit at 9psi in a hatch is more than enough to run mid 12's.
it all depends on the size of the turbo.
9 psi on one turbo can produce quite a difference in power compared to 9 psi on another.
oscargsr
06-21-2002 04:13 PM
