Serious Injector question ( about to purchase)
Old Apr 3, 2003 | 11:15 PM
T3T495GSR's Avatar
Default Serious Injector question ( about to purchase)
i just bought a vafc, im running 6.5 psi 12:1 fmu and missnig link
what size injectors should i order? should i just get 310cc and keep the fmu?
or should i get 450cc dsm and resistor pack and ditch the fmu
im totally confused on what to do car is obd1 by the way
Old Apr 3, 2003 | 11:39 PM
T3T495GSR's Avatar
Default Re: Serious Injector question (T3T495GSR)
bump.... is it just the size of the injectors that you do the hack wiht or does it just have to be dsm injectors and resistor box?
can you run rc 440cc with the hack . that way you dont need a resistor box and hack up the harness?
to me
[Modified by T3T495GSR, 8:41 AM 4/4/2003]
Old Apr 3, 2003 | 11:58 PM
red_sir's Avatar
It's just the size of the injector that matters. RC 440 or DSM 450 would both work.
Old Apr 4, 2003 | 01:22 AM
_Endless_'s Avatar
if you went with rc then you don't need any resistor box.
Old Apr 4, 2003 | 01:26 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Serious Injector question (_Endless_)
You do not need to run a resistor box if the injectors are saturated. RC makes both so you would need to find which one it is.
art
Old Apr 4, 2003 | 10:27 AM
T3T495GSR's Avatar
Default Re: Serious Injector question (Arturbo)
with rc 440s dont i still have to cut up my harness adn make the clips fit? i found them new for 200, is this a good deal?
They are RC "SL4-440" is that what i need? i have a 95 gsr turbo
what do i have to do to make them fit? do i need a new harness/ or hack my harness? clips? im clueless thanks
[Modified by T3T495GSR, 7:40 PM 4/4/2003]
Old Apr 4, 2003 | 10:40 AM
T3T495GSR's Avatar
....bump
Old Apr 4, 2003 | 10:51 AM
b18bturbo's Avatar
if you have obd 1 clips you are fine if you have obd II clips you need to cut and wire or by the CPR adapter setup
Old Apr 4, 2003 | 11:05 AM
T3T495GSR's Avatar
Default Re: Serious Injector question (b18bturbo)
thank you very much, so all i need to do is just slide the new ones in? no modification necessary?
jdmboy94
Oct 13, 2010 02:43 PM
CivSiClone_96
Dec 20, 2009 05:52 PM
Built B16A
Jul 4, 2004 06:05 PM
crashtest Sonny
Jul 25, 2003 11:32 AM
sivik2nr
Jun 11, 2003 09:59 PM
