is it ok to boost with stock injectors?
Old Jul 25, 2003 | 01:16 AM
crashtest Sonny's Avatar
Default is it ok to boost with stock injectors?
will the vafc hack work with it also??
Old Jul 25, 2003 | 04:12 AM
MiraiZ's Avatar
Default Re: is it ok to boost with stock injectors? (4g_civic_si)
um ...injector size?? engine????
Old Jul 25, 2003 | 04:24 AM
Burke's Avatar
Banned
Default Re: is it ok to boost with stock injectors? (MiraiZ)
be safe and get a new set of injectors. the cheapest route are dsm 450's are only like $75 - 90. you just have to get a resistor box and splice that in
Old Jul 25, 2003 | 04:33 AM
Happyman's Avatar
Default Re: is it ok to boost with stock injectors? (Burke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Burke &raquo;</TD></TR><TR><TD CLASS="quote">be safe and get a new set of injectors. the cheapest route are dsm 450's are only like $75 - 90. you just have to get a resistor box and splice that in </TD></TR></TABLE>
Screw the resistor box. Go to Radioshack and pick up 4 10ohm resistors and just wire them into the clips.
Old Jul 25, 2003 | 05:08 AM
swlabhot's Avatar
I wouldn't if I were you Get some 440cc or more...
Its doable with the fmu but I'd rather do the hack and get 440s instead.
Modified by swlabhot at 2:20 PM 7/25/2003
Old Jul 25, 2003 | 06:14 AM
Burke's Avatar
Banned
Default Re: is it ok to boost with stock injectors? (swlabhot)
yea the resistors do the same thing. they just dont look as pretty sometimes. you can pick up the resistors for like $2 or a resistor box for like 10-15
its up to you
Old Jul 25, 2003 | 07:13 AM
Killer_B's Avatar
the resistor box looks a lot cleaner then some of the pics i've seen i ppl splicing in the resistors into the clips. i used Honda plugs to wire up my box and it looks really clean.
Old Jul 25, 2003 | 11:32 AM
Default Re: is it ok to boost with stock injectors? (Killer_B)
can i see some pictures? this is going to be for d16y8.
G0TB00ST
19
Apr 13, 2007 03:30 PM
Built B16A
Jul 4, 2004 06:05 PM
1strdko
Aug 17, 2003 08:56 AM
sivik2nr
Jun 11, 2003 09:59 PM
T3T495GSR
Apr 4, 2003 11:05 AM
