Sensor Help on JRSC GSR
http://www.hondata.com/tech_jrscinstall.html
My buddy is using hondata s200 with boost on his JRSC GSR. The instructions above are still a little weak to a wiring/sensor retarded person like me. Could someone elaborate on the Map sensor relocation step? I am very confused, will the map sensor relocator come with hondata s200 or whats the deal? I appreciate any input you guys have. This thing is going to be tuned by Tom Payn but we need to get this sensor crap striaghtened out before anything happens.
You will have to move the sensor off the throttle body to where it will sense the intake manifold pressure.
I located mine with a zip tie to the throttle cable bracket on the firewall, then attached a hose from the map sensor to a port on the intake manifold next to where the fuel pressure requlator gets its signal. I then fashioned a cover plate for the hole where the MAP sensor used to be and secured it with the MAP sensor's original screws.
As far as I know, this did not come with the Hondata kit, and I'm using P28 with S200B.
GSR-T-
Nov 13, 2003 07:54 AM
bxsi
Jun 16, 2003 09:45 PM
