Search is still down: really simple question.
Old Mar 29, 2003 | 10:16 AM
vwluv10338's Avatar
Default Search is still down: really simple question.
I have been reading posts on SR20's, RB25's, B18b's, ej20's etc. but I still cant get this simple question about tuning answered. If I am running a Hondata and get it tuned for say 15psi for the track, can I just turn down the boosts for the street? Is that how the fuel and timing maps work, as long as it is tuned for a high psi you can always turn it down? All of this assuming I have a block that can handle it.
Eric
Old Mar 29, 2003 | 10:33 AM
b16ahybrid's Avatar
Default Re: Search is still down: really simple question. (vwluv10338)
you can make two different fuel/ignition maps one of high boost and one for low boost...
Old Mar 29, 2003 | 10:37 AM
vwluv10338's Avatar
Default Re: Search is still down: really simple question. (b16ahybrid)
How do you switch between them? If you have the remote button that some boost comtrollers have for high boost, how does the computer change? I know on the UTEC for the WRX you mount a selector switch to change maps for different octane gas.
Eric
Old Mar 29, 2003 | 10:56 AM
b16ahybrid's Avatar
laptop.
I don't have a system that allows me to run different maps so i can answer that question with accuracy
Old Mar 29, 2003 | 12:10 PM
Precision DC4's Avatar
i'm interested in this info too.
so here's a bump.
Old Mar 29, 2003 | 12:52 PM
accordfreak's Avatar
Default Re: Search is still down: really simple question. (BlackIntegraLS)
i called doug about that...if i remember correctly, you have to have it tuned at a max psi you want... say 20psi.. you use the boost controoler to set it at any psi between the tuned psi which is 20psi and of course the wastegate spring...
[Modified by accordfreak, 9:54 PM 3/29/2003]
Old Mar 29, 2003 | 07:09 PM
Foozball26's Avatar
Default Re: Search is still down: really simple question. (accordfreak)
you only have one fuel map, unless you use some engine program to switch to a different map.
how much fuel your engine gets is dependant on how much boost is read on the map sensor. So if you have it on high boost (20 psi) then 8psi will get the same fuel as if you were running low boost of 8 psi.
Like someone said above you tune for max boost and all the other levels will be set.
[Modified by foozball-26, 10:10 PM 3/29/2003]
Old Mar 29, 2003 | 07:47 PM
b16ahybrid's Avatar
Default Re: Search is still down: really simple question. (foozball-26)
He said he was going to run hondata, so that would allow for two different maps.
Old Mar 30, 2003 | 08:13 AM
Foozball26's Avatar
read my whole post man, You CAN have two fuel maps and switch between them but if you tune for 20 psi all the way through your powerband 8 psi will be tuned as well.
Old Mar 30, 2003 | 08:41 AM
falcongsr's Avatar
What is this crap?
yes but thats not necessary, just make one high boost map
and use a boost controller. like a greddy profec b. one map. multiple boost levels. end of story.
Old Mar 30, 2003 | 12:54 PM
vwluv10338's Avatar
Awsome, thanks guys. This is just one question I have always wondered but was never able to answer. It makes me want to get a boost comtroller with the remote high boost button.
Eric
Old Mar 30, 2003 | 01:36 PM
b16ahybrid's Avatar
Default Re: Search is still down: really simple question. (falconGSR)
you two need to calm down a little have a few or something.
I was just pointing out the possibilties he has with using the hondata.
No need to get your panties up in ruffle.......
you can do it either way......neither was is wrong so no need to get upset ........
END OF STORY:
R.A.T.
Aug 15, 2011 12:11 PM
jamelin
Jun 4, 2009 07:10 PM
Rooftop voter
Feb 13, 2009 05:53 PM
Manny86
Jul 3, 2007 05:29 PM
StreetRac3r
Mar 10, 2007 01:34 AM
