screen vs filter (searched)
Old Jan 21, 2005 | 01:00 PM
  #26
LoSt is BlaCk's Avatar
Default Re: screen vs filter (Bailhatch)
just be safe and use a good filter
Old Jan 21, 2005 | 01:35 PM
  #27
HXMan's Avatar
Default Re: screen vs filter (nlc)
Apexi.
I think anyones well built turbo setup at least deserves a filter.
Old Jan 21, 2005 | 01:51 PM
  #28
braintree's Avatar
Default Re: screen vs filter (HXMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I think anyones well built turbo setup at least deserves a filter.
Thats true. I think if you spend a couple of grand building a kit, an extra 75 bucks for a filter is cheap insurace for longevity(sp).
Old Jan 21, 2005 | 03:03 PM
  #29
blackANESE's Avatar
Default Re: screen vs filter (braintree)
I have no room for a filter on my turbo, screen is pretty much the only choice. Is there any k&n filter material you can get that maybe i can put inbetween 2 pieces of screen?
Old Jan 21, 2005 | 03:13 PM
  #30
done's Avatar
if you get a good enough filter, they act like velecity stacks.
Old Jan 21, 2005 | 03:17 PM
  #31
medjosh6's Avatar
25K+ miles with screen and no problems.
btw, my screen recently broke. does anyone know where i can get one?
Home Depot only sells the screen in 10yard lengths or in large quantities.
Old Jan 21, 2005 | 03:54 PM
  #32
EJ1 wilcox's Avatar
Default Re: screen vs filter (blackANESE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackANESE &raquo;</TD></TR><TR><TD CLASS="quote">I have no room for a filter on my turbo, screen is pretty much the only choice. Is there any k&n filter material you can get that maybe i can put inbetween 2 pieces of screen?</TD></TR></TABLE>
I don't know about K&N material but Edelbrock makes some filter element that you can buy... I think it's like $10... it's basically a big square of foam filter element...
I was going to sandwich some between some screen on my set up but ended up finding a small enough filter instead...
If I didn't have enough room for a filter I would at least use some of the foam Edelbrock stuff, at least that way you are filtering out the dust too...
Old Jan 21, 2005 | 03:55 PM
  #33
r_Senik's Avatar
Default Re: screen vs filter (EJ1 wilcox)
screen....had it for like 6 months now.....used the screen from a screen door.
Old Jan 21, 2005 | 07:01 PM
  #34
Tchleung's Avatar
it's already been proven through tests that the best filterin device was the Apexi. I believe K&N came seocnd. HKS was thw worst, I think Blitz style awas not far from HKS.
Old Jan 21, 2005 | 07:23 PM
  #35
blackANESE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks man, I'll look into that
Old Jan 21, 2005 | 07:27 PM
  #36
wantboost's Avatar
Who is Mr Robot?
that would be soooo restrictive. The screen itself already occupies some air space, combine that with a filter, try breathing through a straw and see how long you stay concious
Old Jan 21, 2005 | 07:29 PM
  #37
DefiantGSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HXMan &raquo;</TD></TR><TR><TD CLASS="quote">Apexi.
that looks pretty~
Old Jan 21, 2005 | 07:30 PM
  #38
wantboost's Avatar
Who is Mr Robot?
Default Re: screen vs filter (DefiantGSR)
^burns stainless is always pretty
Old Jan 22, 2005 | 11:58 AM
  #39
sporkcrx's Avatar
Default Re: screen vs filter (wantboost)
Anyone know if those UNI filters flow good? They must if they go on 12,000 rpm bikes right?
Old Jan 22, 2005 | 12:30 PM
  #40
631 Teggy's Avatar
Default Re: (Tchleung)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tchleung &raquo;</TD></TR><TR><TD CLASS="quote">it's already been proven through tests that the best filterin device was the Apexi. I believe K&N came seocnd. HKS was thw worst, I think Blitz style awas not far from HKS.</TD></TR></TABLE>
I remember reading this as well. The Apex flowed the best, and kept out the most dirt. And like you said, those foamy filters don't work for ****.
Old Jan 22, 2005 | 01:02 PM
  #41
TurboCoop's Avatar
I started off having just a screen (it was the gray metal wire screen from home depot) because I couldnt get a filter straight on the turbo, and I didn't have a pipe to extend it. That worked for like 8 months with no problems. When I got a new manifold I got a little straight pipe to go out to a filter. I was going to get a K&N but it was $70, so I got a cheap $30 one from Autozone or somewhere. I could definitely tell it was slower spooling up with the filter, so I switched back to the screen. It is my daily driver too, so I would reccomend the screen, you can even double up with the screen if you think the holes are still to big.
Old Jan 22, 2005 | 01:04 PM
  #42
Rory Breaker's Avatar
Default Re: (631 Teggy)
After making some modifications to my setup, I couldnt fit the intake arm on due to the stock fan moving a bit, so I just slapped a screen on and drove around on it. One day, I hammered it and went "this feels like absolute ****". Top end was hurtin, it just wasnt pulling hard. I made a few pulls throughout the day, it felt awful.
I figured Id see if the screen had anything to do with it. Went out, got a slimfan, hooked the intake back up, went for a drive and whaaaaaaam back in action. This isnt butt dyno 3whp, this was night and day.
The only benefit to the screen was that SOB spooled LOUD!
Old Jan 22, 2005 | 01:40 PM
  #43
BigMoose's Avatar
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">I got news for ya, a screen will make less power than a filter, i've done it time and time again on the dyno. Compare the surface area of a screen to that of a filter...</TD></TR></TABLE>
Listen to tony1... That screen is not as open as you think. The flow does not like the aluminum mesh at all. The "effective" flow area is only around 60% of the "actual" open area of the screen.
Old Jan 22, 2005 | 01:59 PM
  #44
racinskittle's Avatar
I think blitz was one of the best too. It didn't filter much, but it had pretty much the best airflow.
Also, if i had room for a filter i'd be running one. I gotta figure something out b/c my mesh is starting to worry me.
Old Jan 22, 2005 | 04:46 PM
  #45
TurboTagTeam's Avatar
My friends turboed gsr(sc35) last about 30Hp to a filter. The difference between a filter and a screen was like night and day. I can see were running a filter would be better for realiability though.
Old Jan 22, 2005 | 05:45 PM
  #46
Benjithx's Avatar
Default Re: screen vs filter (TurboTagTeam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTagTeam &raquo;</TD></TR><TR><TD CLASS="quote">My friends turboed gsr(sc35) last about 30Hp to a filter. The difference between a filter and a screen was like night and day. I can see were running a filter would be better for realiability though.</TD></TR></TABLE>
So true, I made a run on the dyno with out my filter and made 25 more hp. I have a Big K&N too. I was pissed but still run it because i think it is safer.
Old Jan 22, 2005 | 05:51 PM
  #47
tony1's Avatar
Default Re: screen vs filter (Benjithx)
I have yet to see a car pick up significant hp with no filter as opposed to a PROPERLY SIZED air filter in good condition. Even at 400-500hp, a normal sized K&N shoudn't be a restriction.
miahjera04
Dec 14, 2017 04:06 PM
phaiwezzie
Mar 28, 2008 04:21 PM
turboH22Aakkord
May 18, 2005 06:26 PM
osuperjohno
Jun 11, 2004 07:20 AM
RedHackBatch
11
Dec 16, 2003 03:20 PM
