Scatter shield or no scatter shield?
Old Apr 18, 2002 | 09:35 PM
  #26
ekb18c's Avatar
Default Re: Scatter shield or no scatter shield? (Slow_ass_4dr)
this will go back and forth from a hydro to cable tranny case right?
If you asking if they are interchangeable, the answer is no. A scatter shield for a cable tranny is different then a scatter shield for a hydro tranny.
Old Apr 18, 2002 | 09:37 PM
  #27
earl's Avatar
Default Re: Scatter shield or no scatter shield? (ninesecrx)
If you are running on the street, that should make your passenger real happy
Old Apr 19, 2002 | 06:48 AM
  #28
J2turbo21's Avatar
Default Re: Scatter shield or no scatter shield? (ekb18c)
I know that,but how do i keep something like a shatter flywheel from ******* up my motor heheh.
[Modified by J2turbo21, 3:49 PM 4/19/2002]
Old Apr 19, 2002 | 09:02 AM
  #29
earl's Avatar
Default Re: Scatter shield or no scatter shield? (J2turbo21)
No way to save the tranny case and sometimes the block eats it also. Scattershield is just to protect you and innocent by standers.
Old Apr 19, 2002 | 09:08 AM
  #30
SEFIxCivic's Avatar
to protect your motor you're going to need a high quality clutch and flywheel combo.
Old Apr 19, 2002 | 09:10 AM
  #31
J2turbo21's Avatar
Default Re: Scatter shield or no scatter shield? (SEFI8LOxCivic)
SO far i have a clutch masters lightned flywheel,and i just need a good *** clutch to hold all this power.Any ideas.
Old Apr 19, 2002 | 09:16 AM
  #32
TurboDANDEE's Avatar
we had a JUN chromoly flywheel, that **** held, nothing wrong with it. the only thing that gave out was the ACT clutch and ripped away from everything around it.
Old Apr 19, 2002 | 10:58 AM
  #33
SEFIxCivic's Avatar
Default Re: Scatter shield or no scatter shield? (JiSATSU RaceR)
yea, that's why i said clutch & flywheel combo. if you're running a decent amount of power and slicks, running modifed stock pressure plates (ie. ACT, Clutchmasters) is a hazard to your drivetrain. You want something that's designed to take the abuse, for instance the tilton, os giken, clutch masters dual disc.
Old Apr 19, 2002 | 03:17 PM
  #34
J2turbo21's Avatar
ACT and CM have modified stock pressure plates?So there just stock one made to handle more power?Thats shitty.Name some more companies in the $300-$450 price range for clutches,i need a good one.Thanks
Old Apr 19, 2002 | 07:35 PM
  #35
earl's Avatar
Untrue, both ACT and CM (at least on their high end clutches) are mostly custom made parts for the clutch. Better quality center sections, bigger rivets, stronger diaphrams, etc. Lots of reasons for a clutch to explode and not all of them the fault of the mfg.
Old Apr 22, 2002 | 05:39 AM
  #36
Dublocivic's Avatar
Default Re: Scatter shield or no scatter shield? (earl)
The CM stage 5 I have is all new quality stuff.
Old Apr 22, 2002 | 03:53 PM
  #37
SEFIxCivic's Avatar
true, lots of people use ACT/CM with success. i guess im just a sucker for marketing but at the same time i've seen pictures of the destruction of a clutch letting go, and it tags the tranny and block turning them into garbage.
Old Apr 22, 2002 | 05:50 PM
  #38
b18bturbo's Avatar
The clutchmasters/ACT combo is nice but wehn you bust over 350fltbs every day and harsh launches you gonna destroy your tranny and shooot your pressure plate outside the trannsmission. Like Sefi says you must go with a high qualy clutch combo that wont get destroyed. Such as
Tilton
Os geiken
ClutchMaster dual Disc
RPS carbon
Old Apr 22, 2002 | 10:35 PM
  #39
SEFIxCivic's Avatar
Default Re: Scatter shield or no scatter shield? (b18bturbo)
i don't mean to scare anyone but check out what St00pid posted on CSi.
Old Apr 22, 2002 | 10:38 PM
  #40
SEFIxCivic's Avatar
and the worse part is i've seen worse. imagine the heartache of screwing over a fully built turbo block, which has happened.
Old Apr 23, 2002 | 02:07 AM
  #41
degradated's Avatar
New User
Default Re: Scatter shield or no scatter shield? (newspeedR)
If you run track event and run faster than 11.99, they are required...
Just wondering...
Do all tracks have this rule? Is there any way to visually inspect that you have a scattershield in (seems like you could just "say" you have a scattershield if you have an 11 second car)?
Old Apr 23, 2002 | 02:29 AM
  #42
SEFIxCivic's Avatar
Default Re: Scatter shield or no scatter shield? (degradated)
here's a link that shows what the scatter shield looks like.
http://www.goldeneaglemfg.com/scattershield.htm
[Modified by SEFI8LOxCivic, 11:31 AM 4/23/2002]
Old Apr 23, 2002 | 06:16 AM
  #43
J2turbo21's Avatar
So if im not going over 350lbs of tq then i should just go with an act or cm clutch?
Old Apr 23, 2002 | 08:20 AM
  #44
BoostinDC2's Avatar
Just wondering...
it really depends on which track if it is a NHRA track 11.99 or quicker must run a scatter shield. but if it is a IHRA track 11.49 and quicker must run a scatter shield.
jacky599r
Dec 3, 2012 02:35 PM
Topdawgg
Dec 3, 2006 01:27 PM
dAng! Kris
Feb 28, 2005 01:49 PM
darkmarc
Aug 13, 2004 06:16 AM
shockerstickers
May 14, 2003 08:19 AM
