sc61 on a stock ls block
Old Jun 20, 2005 | 11:12 PM
redlseg's Avatar
Default sc61 on a stock ls block
does anyone have this turbo on there stock ls. if so what size injectors are u using and how many pounds are u boosting at? and how much hp are u at
Old Jun 21, 2005 | 07:29 AM
adseguy's Avatar
Default Re: sc61 on a stock ls block (h-tman)
your powerband will suck a fat one with that turbo. . Unless you are building it up and reving to 8k, I really wouldn't get this turbo.
Old Jun 21, 2005 | 07:51 AM
Rod.'s Avatar
Default Re: sc61 on a stock ls block (adseguy)
https://honda-tech.com/zerothread?id=770102
probably find a lot of info here
Old Jun 21, 2005 | 11:17 AM
redlseg's Avatar
Default Re: sc61 on a stock ls block (redturbocivic)
thanx guys for the info, i already got the turbo though brand new for half price cause a friend needed money. if i were to rev up to 8k with stock internals. could i at least make the 300hp mark with a decent power band?
Old Jun 21, 2005 | 11:34 AM
adseguy's Avatar
you'll get 300whp very easily with this turbo, but your powerband will suck a fat one ...playing with a 2 thousand RPM is not very cool unless it's for the dragstrip
Old Jun 21, 2005 | 11:46 AM
Chip's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h-tman &raquo;</TD></TR><TR><TD CLASS="quote">thanx guys for the info, i already got the turbo though brand new for half price cause a friend needed money. if i were to rev up to 8k with stock internals. could i at least make the 300hp mark with a decent power band?</TD></TR></TABLE>
Power is dropping like god damn rock by 7K. Revving to 8K is worthless.
Old Jun 21, 2005 | 12:28 PM
adseguy's Avatar
Default Re: sc61 on a stock ls block (Chip)
actually torque starts to drop at 6000. That's why redline is 6800. With a built head though revving to 8 grand the torque won't drop as bad. I was almost going to say your playing with a 1k powerband, but then people would have gotten on my ***...lol
Old Jun 22, 2005 | 11:03 AM
redlseg's Avatar
can anyone post a dyno sheet with a stock ls block and a sc61? i want to see how the power band is
Old Jun 22, 2005 | 11:14 AM
rough_draft's Avatar
sell it and buy a diff turbo
Old Jun 22, 2005 | 11:35 AM
redlseg's Avatar
Default Re: (Lmaonade)
i plan on building this ls motor up in a couple of months. i plan to at least make 500hp with it fully built. but as of right know, i just want to see how it performs on a stock ls . and right now my garrett turbo is going to ****, so i really need to put a new turbo on. and i'm just curious what the power band will look like before i install the sc61 on my stock ls.
G
sh!t happens.
sc34 on a ls is nice get a vtec head and do ls/vtec
Old Jun 22, 2005 | 11:40 AM
Blue98Ex's Avatar
My boy is running an LS with 81.5mm pistons, rods, and blockguard with a completely stock head with an SC61 and it runs like a champ... Mase tuned at 417whp 340tq and ran a 12.9 at 113 i believe it was. The 12.9 run was on nitto 555r's, pump gas, low boost, and this is a full interior 95 ex civic with leather seats and AC. I know its not stock but it has almost stock bore, has stock compression, and only revs to about 7200rpms on stock head. The car easily beats mustangs, srt-4, STI's, ect. with 18 volk rims, a bomex kit, full interior, and on 93 pump gas running 13 psi. Hope that might help
Old Jun 22, 2005 | 11:55 AM
s2kdre's Avatar
Default Re: (Blue98Ex)
powerband is not bad at all, i had that turbo with an fmu at 7 psi for a while, now im gonna run 15-20psi
Old Jun 22, 2005 | 01:39 PM
Chip's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blue98Ex &raquo;</TD></TR><TR><TD CLASS="quote">My boy is running an LS with 81.5mm pistons, rods, and blockguard with a completely stock head with an SC61 and it runs like a champ... Mase tuned at 417whp 340tq and ran a 12.9 at 113 i believe it was. The 12.9 run was on nitto 555r's, pump gas, low boost, and this is a full interior 95 ex civic with leather seats and AC. I know its not stock but it has almost stock bore, has stock compression, and only revs to about 7200rpms on stock head. The car easily beats mustangs, srt-4, STI's, ect. with 18 volk rims, a bomex kit, full interior, and on 93 pump gas running 13 psi. Hope that might help </TD></TR></TABLE>
Yeah, look at that stellar powerband he has with an SC61
Old Jun 22, 2005 | 08:03 PM
redlseg's Avatar
Default Re: (Chip)
i was thinking about changing the exhaust housing from .63a/r to .48a/r. if i do this will i need to also change out the turbine wheel on the exhaust side?
Old Jun 22, 2005 | 10:07 PM
redlseg's Avatar
Default Re: (h-tman)
anyone? and does anyone know where i can buy a new exhaust housing and maybe the turbine if i need it?
Old Jun 22, 2005 | 11:31 PM
redlseg's Avatar
Old Jun 23, 2005 | 08:47 AM
redlseg's Avatar
Old Jun 23, 2005 | 11:59 AM
TheShodan's Avatar
Moderator
Changing the A/R in that situation is unfortunately useless. Maybe someone will give the map of one, most won't. I'd resell and find another solution.
Old Jun 23, 2005 | 02:38 PM
alpha's Avatar
A lot of heat soak but you get the idea of what the powerband will look like.
https://honda-tech.com/zerothread?id=1283823
bigboom
Mar 26, 2010 07:00 PM
fireblaze2k1
Mar 14, 2009 03:15 AM
norcalbayboy
Apr 30, 2007 12:48 PM
Mstec
Dec 31, 2006 04:41 PM
lubmyinteg
Feb 26, 2006 06:03 PM
