LS turbo build up, stock block question
How much HP will the stock bottom end of a B18A1 with ARP rodbolts be good for? I want 200-225HP for a decent price without dropping $$$$ on building the bottom end.
Re: LS turbo build up, stock block question
your goal is reachable,if you are not tuned i would not boost more than 8psi.Im boosted LS stock block untuned putting out 200 whp on 7psi
You don't need to do anything to the motor except to make sure it has good compression. Do a search on LS Turbo or look at the huge LS Turbo thread and you'll see plenty of people making 300 whp on 100% stock long blocks.
OP, your 2nd quote in your sig made me spit Dr. Pepper on my keyboard!
Man U FTW
You have very attainable goals, but dont listen to people who give you goals in terms of PSI. That's a totally irrelevant measure. The safe range for your stock bottom end is ~300whp. Stay under that with a good tune and you'll be just fine
THELS98
10-06-2005 07:30 PM
