Sc61 Spool Time
Old Dec 10, 2003 | 05:26 PM
Grubb's Avatar
Default Sc61 Spool Time
I have a question about the sc61, ive searched on the board for about an hour and a half and cant come up with exact numbers...what are the spool up times for the sc61? ive seen a few posts that say around 5000rpm...but i dont think they were exact and were just estimates. Also, are there certain variables other than the size of the turbo that govern spool times?
Old Dec 10, 2003 | 05:41 PM
Boostage's Avatar
Default Re: Sc61 Spool Time (h22_hatch)
from everything I learned here. the bigger the Dp and exhaust is is the quicker the spool time is basically try to eliminate as much back pressure as you can. also bore size, U having an h22 I dont think lag would be much of an issuse for you. even with a 2.5 inch exhhaust. but all those, tuning, proper a/r ratio and even porting the head all contribute big time. I doubt it will take an h22 5k to see 10psi
Old Dec 10, 2003 | 06:48 PM
JGurr81's Avatar
Default Re: Sc61 Spool Time (Ateyour2JZ)
https://honda-tech.com/zerothread?id=700491
https://honda-tech.com/zerothread?id=698984
Look at these two threads, they should help. Search too, there are good topics in the archives.
TylerB
Sep 15, 2007 07:20 AM
lshatch59
May 4, 2007 06:19 PM
Non-Vtec101
Oct 20, 2003 12:18 PM
