sc34 or t3to4e
Old Nov 17, 2003 | 09:21 AM
arjusmc's Avatar
Default sc34 or t3to4e
i'm stuck between the two. do you guys think it would be worth it to buy the precison if i'm only going to boost 9-10psi max. i'm running a drag mani and dp. intercoolered using an afc and some dsms with 2.5 all the way back exhaust.by the way its on an ls. i can't decide.
Old Nov 17, 2003 | 09:26 AM
99B16Si's Avatar
its all in if your willing to spend the money
Old Nov 17, 2003 | 09:27 AM
sydag5's Avatar
Default Re: sc34 or t3to4e (arjusmc)
yes go with precision
edit
Old Nov 17, 2003 | 09:44 AM
ELSpool's Avatar
Not to disrespect precision, but I would really like to see some dyno's of Garrett vs Precision for power levels under 400whp. ie. SC-50 vs. 50 Trim Garrett. It seems like in the big power levels, the precision works well, but is it worth the extra dollars for 350whp?
Old Nov 17, 2003 | 10:04 AM
yellowturbo's Avatar
would like to know what ELspool asked too ...
Old Nov 17, 2003 | 12:55 PM
arjusmc's Avatar
Default Re: (ELSpool)
what size garret would be comparable to the sc34. thats one of my hang ups with precison. I'm not sure what size i should go with. I'm willing to pay the difference. after all i have spent the difference isn't much for better perfomance. I'm just not sure that it will outperform the garret at lower boost levels. when talking to the guys at cheapturbo.com i was recommended this one
COMPRESSOR SPECS:
.60 A/R HOUSING
57 TRIM WHEEL
TURBINE SPECS:
.48 A/R HOUSING
STAGE 3 WHEEL
standard with 270 degree thrust bearing
Old Nov 17, 2003 | 01:17 PM
Arturbo's Avatar
Better than steak
25 Year Member
The SC34 uses the Garrett 57 trim T04E.
art
B18Flip's Avatar
Default Re: (arjusmc)
from what i've read the only difference between them are the compressor and turbine housings, and the 360 bearings....other than that the bearing housing and wheels are the the same.
Old Nov 17, 2003 | 01:49 PM
arjusmc's Avatar
Default Re: (B18Flip)
so the performance will be nearly the same or the spool time will be nearly the same? I've been leaning toward the sc34 for some time,ah time for more research.
Old Nov 17, 2003 | 02:02 PM
30psi Teg's Avatar
Precision but I just like their service and support.
Old Nov 17, 2003 | 02:11 PM
Boltz's Avatar
Default Re: (30psi Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 30psi Teg &raquo;</TD></TR><TR><TD CLASS="quote">Precision but I just like their service and support.</TD></TR></TABLE>
Old Nov 17, 2003 | 06:12 PM
arjusmc's Avatar
i think i'll call precision tomarrow and see what they can tell me about the sc34 or other precisions.
Old Nov 24, 2003 | 01:24 PM
Sylverius's Avatar
Feel free to relay your findings, I'm in a similar boat.
- Jim
94VTEC2TONE
Feb 8, 2011 02:10 PM
rollagti
Nov 27, 2006 05:59 AM
JDM_EH2
Jul 24, 2005 08:13 PM
b18cTurbo
Jul 8, 2003 12:41 PM
