Problem with Aeromotive FPR
Old Nov 3, 2003 | 09:22 PM
I Like Boost's Avatar
Default Problem with Aeromotive FPR
I have the Aeromotive external fuel pump, fuel filter and Fuel pressure regulator with upgraded lines. I have had this setup working fine for over a year and now i'm having a problem. My car was acting weird and kinda sluggish and seemed to be running rich.
So i started the car and checked the fuel pressure gauge i have on my rail. It is supposed to be at 50psi at idle, i checked and it was at 65psi. No problem, i'll just turn it down. This happened once or twice before and i was able to turn it back down to 50. So i loosen the nut and with a allen key turn it counter clockwise, the fuel pressure dosn't go down! I turn it clockwise and it raises it, but it won't turn down.
WTF how can i fix this problem, i really don't want to buy a new one. What went wrong with the regulator, can i just buy a part and replace it, HELP
CLIFF NOTES for the lazy - Aeromotive regulator won't decrese my fuel pressure back to where its supposed to be
Old Nov 3, 2003 | 10:13 PM
Default Re: Problem with Aeromotive FPR (IMPULSE B18C-T)
Would Aeromotive warrenty their products? Anyone have any thoughts on this, help please i am wasteing a shitload of gas.
Old Nov 3, 2003 | 10:17 PM
porsche997dc2's Avatar
Is there any way you can put back the stock one?
Old Nov 3, 2003 | 10:24 PM
Default Re: Problem with Aeromotive FPR (porsche997)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by porsche997 &raquo;</TD></TR><TR><TD CLASS="quote">Is there any way you can put back the stock one?</TD></TR></TABLE>
no way in hell, way to restrictive for my setup.
Old Nov 4, 2003 | 11:35 AM
Old Nov 4, 2003 | 11:38 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IMPULSE B18C-T &raquo;</TD></TR><TR><TD CLASS="quote">
no way in hell, way to restrictive for my setup.</TD></TR></TABLE>
How much whp is your engine put out?
Old Nov 4, 2003 | 11:39 AM
DaveF's Avatar
have you tried a differant guage?
maybe a "spring or something" went bad in the FPR, or its clogged somehow...vacum port clogged maybe??
Old Nov 4, 2003 | 11:42 AM
gritsak's Avatar
Default Re: Problem with Aeromotive FPR (2.2Lcivic)
you can take apart the regulator and make sure theres nothing clogged up in there
Old Nov 4, 2003 | 11:45 AM
You can open it up to check the spring inside and the diaphragm. It's not that hard because I had opened it before.
Old Nov 4, 2003 | 11:48 AM
Default Re: Problem with Aeromotive FPR (gritsak)
How much whp is your engine put out?</TD></TR></TABLE>
Right now 350whp on pumpgas
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gritsak &raquo;</TD></TR><TR><TD CLASS="quote">you can take apart the regulator and make sure theres nothing clogged up in there</TD></TR></TABLE>
Well i guess thats what i'll have to do, i hate working on fuel system parts. How should i go about making sure gas isnt gonna spray everywhere?
Old Nov 4, 2003 | 11:49 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.2Lcivic &raquo;</TD></TR><TR><TD CLASS="quote">have you tried a differant guage?
The gauge is good, i can tell it's way rich - runs like ****, backfires, and black smoke out the exhaust.
Old Nov 4, 2003 | 11:51 AM
PM-Performance's Avatar
check the gauge 1st, i have had probs with the gauges already , they wont read accurately. like the needle will only go to a certain point on a low level. like will read 50 and up , but not below, kinda hard to explain .
but if that dont do it . check the diapram in the FPR.
Tinker219's Avatar
Well i guess thats what i'll have to do, i hate working on fuel system parts. How should i go about making sure gas isnt gonna spray everywhere?</TD></TR></TABLE>
take it off the car
this happened to me as well, except I was up at around 80 psi....I ditched the project before I could really do anything about it, but I still ahve the FPR...itd be nice if you could remedy this, I need it for my up and coming rwd project
Old Nov 4, 2003 | 11:53 AM
Default Re: Problem with Aeromotive FPR (itr206)
I'm gonna go remove it, I'll get back to you guys with what went wrong. Thanks for the help.
I H-T
Old Nov 4, 2003 | 01:05 PM
h22 civic's Avatar
check your return line also for kinks or clogs or maybe just to smalll
Old Nov 4, 2003 | 01:06 PM
DrkGreenAccord's Avatar
Yes please reply back with results...... Most of post that the poster needs help ends in them not saying how they fixed it. (Maybe they never fix it )
Good Luck to you
Old Nov 4, 2003 | 07:26 PM
Default Re: Problem with Aeromotive FPR (h22 civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22 civic &raquo;</TD></TR><TR><TD CLASS="quote">check your return line also for kinks or clogs or maybe just to smalll</TD></TR></TABLE>
Great advice, I just got an email from Aeromotive saying the exact same thing. To bad it's to dark to work on my car now. The size of the line is not the problem, I already had this setup working perfect for quite awhile.
Its been raining mostly all day but i did get a chance to take off the FPR. It's a very simple and well made piece, very easy to remove and take apart. Everything seemed to be in perfect condition, no visiable signs of wear at all.
I'm gonna check out my return line in the morning but how should i go about doing it, just a visual inspection????
Old Nov 5, 2003 | 12:00 AM
Mista Bone's Avatar
D Tranny Guru
what aeromotive FPR you using??????????
On the Honda Rail mount units, the vacuum port fitting hits against the spring, locking it in place!
Aeromotive has NEVER returned my calls either!!!!!!!
Old Nov 5, 2003 | 08:22 AM
Default Re: Problem with Aeromotive FPR (Mista Bone)
Mine is not on the fuel rail, i have it agenst the firewall. Aeromotive was very quick to reply to an email i sent to the tech@aeromotiveinc.com. This morning i put the FPR back and check my return lines for kinks but i could not find anything. The fuel pressure still won't go less than 60 psi. WTF
Old Nov 10, 2003 | 09:23 AM
Still havn't resolved this problem
Old Nov 10, 2003 | 09:42 AM
toxicshit's Avatar
buy and try a new return line !! ??
Old Nov 10, 2003 | 10:11 AM
Gravy's Avatar
Default Re: Problem with Aeromotive FPR (toxicshit)
hey john i have all aeromotive fprs in stock. come down to murrays in miami. im sure we have what you need.
Old Nov 10, 2003 | 10:51 AM
MotorMatrix.com's Avatar
I am a bad person
Default Re: Problem with Aeromotive FPR (Gravy)
take it apart and i bet you the spring inside broke. Chris greens jetta had that happen with the same regulator. spring was in 2 pieces. you can buy just the spring i beleive.
Old Nov 10, 2003 | 11:12 AM
Default Re: Problem with Aeromotive FPR (MotorMatrix.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MotorMatrix.com &raquo;</TD></TR><TR><TD CLASS="quote">take it apart and i bet you the spring inside broke. Chris greens jetta had that happen with the same regulator. spring was in 2 pieces. you can buy just the spring i beleive.</TD></TR></TABLE>
I already took it apart everything was in perfect shape.
Old Nov 24, 2003 | 01:28 PM
tgreaves's Avatar
You might have a blockage in your return line somewhere.. ....I know this isnt safe but put the return part of the fpr into a coke bottle and pressurize the fuel system.. See if you can adjust the pressure then.. I had a blocked return line on mine and this test showed me just that..
91tealhatch
Nov 3, 2008 07:10 AM
C70Civic
Jan 4, 2004 08:48 AM
C70Civic
Jan 2, 2004 10:11 PM
b18c1-ek
May 29, 2002 04:44 PM
JM Performance
Dec 20, 2001 03:51 PM
