SC/TC b20b ?
Old Jun 2, 2003 | 03:45 AM
GumballNA's Avatar
Default SC/TC b20b ?
just curious out there to see if anybody has done either... and which would be best for me...
I ran into a girl that works for ProCharger, and that can get me one for alot cheaper then retail cost? now... im in the stages of planning, im going to be purchasing a B20B motor, for my EJ (dx) and throwing that on there, but I found out from her (which i did not know) that you can upgrade the boost to almost 30psi of boost with the ProCharger, and i know SC's r much less matience then a TC would be, but from my research on turbos u can do so much more?
On my coupe im looking to get at least 11's on a Daily Driven car... which would be mroe suitable?
Old Jun 2, 2003 | 04:22 AM
b20turboic's Avatar
Default Re: SC/TC b20b ? (Type-X)
turbo.... super charger will give a b20 way to much low end which it already has what it needs its top end which a turbo will do much much better also SC's have heating problems do to no intercooler (except vortec). My turbo has no mateince but the tuning which for a super will need anyway if you dont wanna pop your motor .... turbo is the only way to go my .02
Old Jun 3, 2003 | 04:42 PM
GumballNA's Avatar
Default Re: SC/TC b20b ? (b20turboic)
hey i apperciate it man, but r u running just b20? no GSR/b16/itr/ctr..etc. head on there? and what turbo r u running? and what's ur times, and what chassis?
Old Jun 3, 2003 | 05:05 PM
boosted92's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20turboic &raquo;</TD></TR><TR><TD CLASS="quote">turbo.... super charger will give a b20 way to much low end which it already has what it needs its top end which a turbo will do much much better also SC's have heating problems do to no intercooler (except vortec). My turbo has no mateince but the tuning which for a super will need anyway if you dont wanna pop your motor .... turbo is the only way to go my .02 </TD></TR></TABLE>
Lol. Wrong blower buddy, you're thinking of JRSC's that give you "too much low end" and not enough top end. A Procharger is the same style of blower as a vortech, but they do come with an air/air intercooler. Don't go for that blower on a honda, it doesn't give you enough of a boost in low end torque, and you probably arn't going to have much fun changing pulleys if you want to change boost. This sounds a bit weird coming from someone who just shelled out a little over 3300 bucks + shipping for a procharger, but that's for a comparitively huge V8. Trust me, go with turbo, you'll be a lot happier.
Old Jun 3, 2003 | 06:09 PM
GumballNA's Avatar
Default Re: SC/TC b20b ? (boosted92)
ya im most likely going to go with turbo, seening how SC's r so fuccing expensive.. i mean sheesh! lol... but i like the stuff u can do with a turbo.. . also u can always change the turbo down the line.. for MUCH more boost.... so ya know?
Old Jun 3, 2003 | 07:51 PM
hybridsol's Avatar
I'm VERY happy with my motor setup, even at 210 Hp. Although I put a DOHC head on, I don't think there is that much difference, as long as you use a skunk/ B18 manifold and a B18 TB- the B20B TB is TINY!
Old Jun 3, 2003 | 08:07 PM
GumballNA's Avatar
Default Re: SC/TC b20b ? (hybridsol)
well... what exactly is ur setup? seening how B20 is already DOHC? u mean like GSR head? and what is everything u have dun? and what's ur times?
Old Jun 3, 2003 | 08:13 PM
dustin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type-X &raquo;</TD></TR><TR><TD CLASS="quote"> I ran into a girl that works for ProCharger, and that can get me one for alot cheaper then retail cost? now... im in the stages of planning, im going to be purchasing a B20B motor, for my EJ (dx) and throwing that on there, but I found out from her (which i did not know) that you can upgrade the boost to almost 30psi of boost with the ProCharger, and i know SC's r much less matience then a TC would be, but from my research on turbos u can do so much more? </TD></TR></TABLE>
Procharger just makes centrifugal superchargers. How would you plan on connecting such a supercharger to your engine? It needs a mechanical connection to turn the SC.
Also, boost level is just the inability of a motor to flow air. So "30 psi" does not really mean anything. I can pressurize a tire to 30psi with a foot pump, but that does not mean that the pump flows much air.
Also, the B20 sleeves like to crack all the time. So be careful.
Dustin
Old Jun 3, 2003 | 08:29 PM
AP-Signworks1's Avatar
Unless you're custom fabbing a whole kit, you can't mount a procharger. It's not like a turbo where you just need a manifold and piping (oversimplified).
And w/ a Procharger, you're not going to have any low end. It's almost the same as a Vortech, and look at that thing, there is like no low end.
I had a Vortech SC setup on my Maxima, and that's a 3.0 L V6 motor, and there was no low end. I can't imagine how bad it would be on a B20. So now I'm going with a custom turbo setup.
Old Jun 4, 2003 | 01:20 PM
GumballNA's Avatar
Default Re: (AP-Signworks1)
ya i've come to the conclusion of turboing it.. btu on my b20b im planning on re-sleeving it anyways.. so hopefully that helps some what i know they r weak around the edges.. same thing with h-series..
94Eg_SnatchBack
Oct 25, 2011 12:41 PM
Ef-er
Jul 1, 2004 02:46 PM
01gizzer
Aug 27, 2002 01:46 PM
