sc-61/.76 trim. is it good.
Old Jul 31, 2003 | 11:46 AM
account deleted's Avatar
Default sc-61/.76 trim. is it good.
i just need to know if i should do with a different turbo i will be using a 83mm gsr block with a stock type r head with gsr cams and a skunk2 manifold. what compression should i run i was thinking 10.0:1 and 15 lbs. thoughts???
Old Jul 31, 2003 | 12:09 PM
Default Re: sc-61/.76 trim. is it good. (NIAScrew)
ttt
Old Jul 31, 2003 | 12:12 PM
Mr. Softee's Avatar
sounds amazing
Old Jul 31, 2003 | 12:52 PM
MotorMatrix.com's Avatar
I am a bad person
at 10:1 and 15psi it should be around 420+ easy.
Old Jul 31, 2003 | 01:51 PM
rOby's Avatar
Default Re: sc-61/.76 trim. is it good. (MotorMatrix.com)
as good as it gets.
Old Aug 1, 2003 | 08:30 AM
Default Re: sc-61/.76 trim. is it good. (rOby)
thanks guys what do you think about using the gen6 accel dfi
Old Aug 1, 2003 | 11:04 AM
turbo Si's Avatar
Why not go with the DFI Gen 7,
https://honda-tech.com/zerothread?id=579346
Old Aug 1, 2003 | 11:25 AM
Drag_On's Avatar
Go with Hondata.. Make it easy on yourself...
Set up sounds like it couldn't get much better.. 420 whp BUT still have off boost power and nice flat curves..
Good luck and good plan.
kpop
10
Mar 20, 2008 10:31 PM
ONE*SICK*FERIO
Feb 27, 2008 09:04 PM
es_squared
Jan 13, 2008 09:11 AM
spoolin_teg
May 9, 2007 06:23 PM
j87w
Jun 22, 2005 06:21 PM
